744
OxygenOS Open Beta 22 for the OnePlus 5 and Open Beta 20 for OnePlus 5T
  1. Hafeez Lucky
    Eclair Dec 15, 2018
  2. Hebbnag
    Gingerbread Dec 15, 2018
    Hebbnag , Dec 15, 2018 :
    it's only for op5t not for op5
  3. PokiX
    Jelly Bean Dec 15, 2018
    PokiX , Dec 15, 2018 :
    Works fine here.
    Does google maps have location permission?
    Then clear cache and data of application and start it again.
  4. Edson22
    Eclair Dec 15, 2018
    Edson22 , Dec 15, 2018 :
    Atualizei pro Beta Aberto do Android Pie e tá acontecendo alguns bugs como por exemplo, esse da barra de notificações fica preta com todos os papéis de parede, mas não é o tempo todo que acontece isso.
  5. daster_x
    daster_x , Dec 15, 2018 :
    thank you OnePlus for this update.
    on my 5t everything works properly... some small issues (Bluetooth quality sometimes is degraded, sometimes animation is luggy)... but these are happening really sometimes without impacting my daily usage.
    some issues/questions which I had before, I found solution in post 2.
  6. kaphlerisi
    kaphlerisi , Dec 15, 2018 :
    tired these things already and still gps location is unavailable mostly to maps.
    I used camera which got location.
    Google maps mimics that very location obtained by camera app with failure to update location seamlessly.
    means Google maps accessing successfully location history tracked already by device but failing to gain first hand access to location.
  7. G1510887316124
    G1510887316124 , Dec 15, 2018 :
    Til now only issue am facing is battery draining faster than before. Hope wil be fixed in the coming beta update
  8. Awa6654
    Froyo Dec 15, 2018
    Awa6654 , Dec 15, 2018 :
    i have observed camera flickering under lighted conditions...rest all working
  9. H1517807453434
    Donut Dec 15, 2018
    H1517807453434 , Dec 15, 2018 :
    Pill gesture isn't working even after clearing the launcher cache, anyone else with similar issue!
    any workaround?
    Trevor.Hawkes likes this.
  10. F_João_Vítor_Arruda_ct
    Eclair Dec 15, 2018
    F_João_Vítor_Arruda_ct , Dec 15, 2018 :
    Estranho, aqui ta normal. Essa att ta toda coisada, cada hora um bug diferente...
  11. Edson22
    Eclair Dec 15, 2018
    kkk pois é né....ainda tá em Beta. não se pode esperar muito né ‍♂️
  12. mahaseeb
    Cupcake Dec 15, 2018
    mahaseeb , Dec 15, 2018 :
    uninstall the launcher and update
  13. G_Raghav_Sambrey_sVsK
  14. Buntaci
    Donut Dec 15, 2018
  15. Rambo15
    Froyo Dec 15, 2018
    Rambo15 , Dec 15, 2018 :
    I can't understand why some of you have so many problems with WhatsApp, Netflix or anything else like mobile data or W-lan.
    Before you install the beta pie mobile phone on factory rest and then install and actually it stands everywhere so described and quite honestly who has no idea should leave the fingers and wait until the stable pie comes.
    And one thing I have to get rid of this is a beta and that can still produce bugs should be clear to everyone.
    Translated with www.DeepL.com/Translator
    faqir.m.abdullah and niklas389 like this.
  16. mihirbhargava
    mihirbhargava , Dec 15, 2018 :
    This forum is for the development and to bring the issues in the highlight. OnePlus here listens to the issue and get it fixed in the next update.
  17. danvxz
    Honeycomb Dec 15, 2018
    danvxz , Dec 15, 2018 :
    as @Rambo15 said, it's a BETA, expect bugs. If you encounter any bugs, be sure to CLEAN flash the beta and see if it still persists. It's common sense when trying betas or build that hasn't been as thoroughly tested as stable releases.
    Rambo15 likes this.
  18. G1543317900220
    G1543317900220 , Dec 15, 2018 :
    does this fix?
  19. danvxz
    Do you actually think OnePlus browses through 100+ pages of pure crap to find one good bug report? (if even that)
  20. mihirbhargava
    There is a dedicated team and with all the issues, an escalation is raised regarding that so that issues can be resolved. This is one of the medium for the issues.
