744
OxygenOS Open Beta 22 for the OnePlus 5 and Open Beta 20 for OnePlus 5T
  1. PokiX
    Jelly Bean Dec 15, 2018
    PokiX , Dec 15, 2018 :
    But first the bug should be reported.
    Then apply this workaround to clean flash.
    It is NOT required to clean flash, otherwise OP would have mentioned it.
  2. Rambo15
    Froyo Dec 15, 2018
    Rambo15 , Dec 15, 2018 :
    If I see otherwise bugs should be reported via the bughunter in this part of the forum no developer will look in or only rarely and if he looks in he wouldn't read 1000 and more posts that has better to do
  3. venkateshreddy2143
    Eclair Dec 15, 2018
  4. mihirbhargava
    Cupcake Dec 15, 2018
    mihirbhargava , Dec 15, 2018 :
    Use Gcam mode, much better than oneplus camera. with night sight
  5. G1543317900220
    G1543317900220 , Dec 15, 2018 :
    i tried it, pictur becomes green after the click
  6. venkateshreddy2143
    Eclair Dec 15, 2018
    venkateshreddy2143 , Dec 15, 2018 :
    is this gcam a sideloaded application. can we install this gcam with out rooting if so could you please share the link
  7. mihirbhargava
  8. venkateshreddy2143
    Eclair Dec 15, 2018
  9. Momintaqweem
    Donut Dec 15, 2018
  10. R1513829112590
    Eclair Dec 15, 2018
  11. mihirbhargava
    You dont even need OTA builds, its is an APK mod by XDA developer.
  12. Chiran_OP5
    Honeycomb Dec 15, 2018
    Chiran_OP5 , Dec 15, 2018 :
    As of now, I don't have any issues on my OnePlus 5. It's working as stable one. I was on H2OS and I format my device before flashing OOS. Might be as I did factory reset before flashing OOS that's why I don't have any issues.
  13. nitrek
    Gingerbread Dec 15, 2018
    nitrek , Dec 15, 2018 :
    1Battery life is not great yet but based on comments above giving it time to set in
    2. Netflix is not working after update I get error video not playing and if I try more than once Phone crashes screen becomes black and notification light is switched on then I have to long press power button to restart phone
    RoyxD4 likes this.
  14. H1517807453434
    Donut Dec 15, 2018
  15. Souvik_Roy
    Froyo Dec 15, 2018
  16. Alok_Hindustani
  17. mk19973
    Eclair Dec 15, 2018
  18. R1511797575535
    Eclair Dec 15, 2018
  19. R1511797575535
    Eclair Dec 15, 2018
    R1511797575535 , Dec 15, 2018 :
    Text message notification is not gone when i opened it once... i have to opened it twice to remove the notification from notification bar.. also swiping the notification is not working to remove it
  20. R1511797575535
    Eclair Dec 15, 2018
