744
OxygenOS Open Beta 22 for the OnePlus 5 and Open Beta 20 for OnePlus 5T
  1. PokiX
    Jelly Bean Dec 16, 2018
    PokiX , Dec 16, 2018 :
    Search the thread, some have problems. If you upgraded to L1 un service center it seems problematic. For non HD with L3 seems fine but application is known to be very buggy anyway..
    aakashsood likes this.
  2. aakashsood
    aakashsood , Dec 16, 2018 :
    Alright! Thanks.[e]1f44d[/e]
  3. RAJATV451
    Cupcake Dec 16, 2018
  4. Grems
    Eclair Dec 16, 2018
    Grems , Dec 16, 2018 :
    Yep, it works.
  5. aakashsood
  6. noquarter
    French POC Assistant Head Moderator Dec 16, 2018
    noquarter , Dec 16, 2018 :
    Post moved from French thread to global discussion.
    Please continue here
  7. deepakdalal
  8. PokiX
    Did you ask on netflix forums?
  9. tomeklives
    Froyo Dec 16, 2018
    tomeklives , Dec 16, 2018 :
    I had the same thing. I was trying to use Google Maps navigation and it kept losing the GPS. Also, there were no audible directions.
    tiritchi likes this.
  10. deepakdalal
  11. tiritchi
    tiritchi , Dec 16, 2018 :
    no sound issue for me nevertheless. but only GPS fix position. we will wait for an update to see if it fix it quickly, hope before holidays ^^
    wait&see
  12. G_Samay_Singh
    Eclair Dec 16, 2018
  13. AnimatedKiller
    Honeycomb Dec 16, 2018
    AnimatedKiller , Dec 16, 2018 :
    Please stop asking about the stable Pie update.
    OnePlus will release it when they feel all the bugs are solved.
  14. tomeklives
    Froyo Dec 16, 2018
    You should be glad. I've been on the beta channel for most of this year and this is the one time I wish I hadn't updated. Losing LTE about half the time makes the phone barely usable.
  15. AnimatedKiller
    India has received it, you need to cross check in system settings.
    And make sure you're mentioning Beta update, if you're on official, please wait for it to officially release.
  16. btobdealals
  17. ReconDonkey
    Froyo Dec 16, 2018
    ReconDonkey , Dec 16, 2018 :
    I have the shutter sound off and it stays off. I don't know what I did different than people that are having problems but pie is running just about as good as stable for me.
  18. mann1147
    Froyo Dec 16, 2018
    mann1147 , Dec 16, 2018 :
    OnePlus are you listening???
    it's a serious bug,pls resolve it or suggest a way out without erasing data.
  19. Souvik_Roy
    Froyo Dec 16, 2018
    gargyagotra likes this.
  20. dineshsd
    dineshsd , Dec 16, 2018 :
    internet speed is not displaying in the status bar it showing in notification..pls check .... also auto birghtness is not working properly in oneplus 5
