744
OxygenOS Open Beta 22 for the OnePlus 5 and Open Beta 20 for OnePlus 5T
  1. Rambo15
    Froyo Dec 17, 2018
    Rambo15 , Dec 17, 2018 :
    To all here the Android 9 flashing want one should always clean flashing
    So you bypass errors especially since there is also a version jump there you should flash clean from home
  2. mmirzyns
    Cupcake Dec 17, 2018
    mmirzyns , Dec 17, 2018 :
    Guys I want to report a stability issue using this one. Sometimes phone just goes down for no apparent reason, with light blue LED and nothing more. I have to reboot the phone afterwards to make it work.
    Zubair2017 likes this.
  3. shubham mirje
    Donut Dec 17, 2018
    shubham mirje , Dec 17, 2018 :
    it's Right
  4. G_indrajith_m_j_eXRL
    Eclair Dec 17, 2018
  5. SP3NGL3R
    Gingerbread Dec 17, 2018
  6. PokiX
    Jelly Bean Dec 17, 2018
    PokiX , Dec 17, 2018 :
    Yes it's even written in the first post.
  7. esoscar
    Donut Dec 17, 2018
    esoscar , Dec 17, 2018 :
    Yes
  8. ErynOP
    ErynOP , Dec 17, 2018 :
    Hey Rambo,
    Could you please tell me how you do your clean flash ? With PC or by local upgrading and erase everything ?
    Thanks.
  9. sanchit singla
  10. Rambo15
    Froyo Dec 17, 2018
    Hi @EryOP am gone from the last open beta 19 to 20 have my mobile phone on factory condition
    and I did a local upgrade and everything works without any problems. The only things I haven't tested are games because I'm not the big gambler.
    Oh yes I have changed before the TWRP against the original recovery and afterwards again TWRP and Magisk after the setup on it
  11. Mr_Cyrox
    KitKat Dec 17, 2018
    Mr_Cyrox , Dec 17, 2018 :
    Well i just used the OTA and atleast for me the OS is really stable and good...
    Didn't do a factory reset but I should do that...
  12. PokiX
    ErynOP
    Hey Rambo,
    Thanks.​
    After flash go in settings in OOS and use factory reset. This will clear data partition. Youll lose application settings but keeps your own userdata(pics, etc..)
    It's also possible to do that from the recovery.
  13. Cosmin13
    Eclair Dec 17, 2018
    Cosmin13 , Dec 17, 2018 :
    I did a clean flash and everything works pretty good. The only bug i found was the face unlock thing, but it happens 1-2 in a day. The animations could use more work (sometimes i can see fps drop) and also the battery is draining a bit faster in this build.
    ierisch likes this.
  14. Lakshya_mandovra_1995
    Donut Dec 17, 2018
  15. vibecheck
    vibecheck , Dec 17, 2018 :
    microphone issue and 3.5mm port issue...3 of my earphones doesn't work after this update
  16. Mr_Cyrox
    KitKat Dec 17, 2018
    I think OnePlus is aware of the issue by know because of multiple bug reports...
    Gonna add mine as well if I don't see many there ;)
  17. SidSince_1995
    SidSince_1995 , Dec 17, 2018 :
    The only issue i have been experiencing in this built is battery draining faster than the previous one.......
    aykut39 likes this.
  18. vibecheck
    crab song intensifies
  19. Mr_Cyrox
    KitKat Dec 17, 2018
    Can anyone confirm that the microphone in this build is not functioning only in 3th party apps like messenger and PUBG?
    I tested it and it seems to work on the default phone app but doesn't work on messenger
  20. animaaryan
    Honeycomb Dec 17, 2018
    animaaryan , Dec 17, 2018 :
    That's a great issue.
    But have you read the first page of the thread itself?
    It clearly says being a new update users will face battery issues, but they will optimise depending on the user's usage overtime.
    Also please remember, this is "Beta Phase"
    If you're really not loving the battery backup, seek for the former update or buy a new device.
