744
OxygenOS Open Beta 22 for the OnePlus 5 and Open Beta 20 for OnePlus 5T
  1. metalhead079
    Gingerbread Dec 18, 2018
    metalhead079 , Dec 18, 2018 :
    I'm afraid I can't mate. Since OnePlus didn't provide us the rollback build to stable Oreo. I'd suggest you to follow the instructions from that video itself.
    If I remember correctly when the first open beta build for Oreo was released OnePlus provides us the rollback to Nougat, but this time they didn't.
  2. saqibrahman7
    Froyo Dec 18, 2018
    saqibrahman7 , Dec 18, 2018 :
    I asked OnePlus support on Twitter, they're asking me to visit a service centre as it's not advisable to Downgrade the OS
    crzfyr likes this.
  3. sr1v3r
    Cupcake Dec 18, 2018
    sr1v3r , Dec 18, 2018 :
    Maybe you're right, I had my phone sent to L1 validation and now with Pie i can't view Netflix, however I can cast it to chromecast.
  4. Prashantchavan26
    Prashantchavan26 , Dec 18, 2018 :
    problem with this update are
    1 online videos on Netflix and other are not working
    2 cemera quality is not good
    3 battery backup is not good
    4 UI is less smooth
    5 navigation gesture need improvement
    hope next update improvement this
  5. Abhishek Kumar Jain
  6. PokiX
    Jelly Bean Dec 18, 2018
    PokiX , Dec 18, 2018 :
    Much is a bit excessive.
    It is a little longer in the last part, battery trickling phase, above 90%(?)
    Could be that the algorithm is optimized for battery longevity or to get the REAL 100%.
    Battery depth of discharge calculation can be complicated.
  7. Darshan_lucifer
  8. Nasir.666
  9. Natarajanvaidhy
    Natarajanvaidhy , Dec 18, 2018 :
    My experience and solution to lots of apps not responding : Please backup your data. Download the Android Pie update. Switch off the mobile and restart in boot mode. Clear cache and factory reset and then update. Restore all apps and setting after factory reset.
  10. BharadwazSarma
    BharadwazSarma , Dec 18, 2018 :
    switch between apps is very glitchy.
    scrolling is very bad
    mobile is losing signal sometimes
    notifications mark as read is sometimes not getting opened (force minimize)
  11. iharshjjain
    Ice Cream Sandwich Dec 18, 2018
  12. Godlysam
    Godlysam , Dec 18, 2018 :
    My microphone has issue while calling watasp call n imo call...
    plz do suggest to get clear of this issue.....normal call are clear
    G_B_Studio_iAdG likes this.
  13. _Stephanie_
    Froyo Dec 18, 2018
    _Stephanie_ , Dec 18, 2018 :
    Nope. It takes 10 minutes to go up even 3 % while under 90. :/
  14. G_vipul_jadhav_ayfz
    G_vipul_jadhav_ayfz , Dec 18, 2018 :
    Few days before i got my device updated to Android pie after that whenever I am trying to connect my laptop to my device hotspot it's not working my laptop is unable to find the device...
  15. bgpancha
    bgpancha , Dec 18, 2018 :
    I'm running this open beta on my OnePlus 5, Clean install, After a week of use I haven't encountered any major issues or bugs,its daily driver ready, with occasional freezes/stutters, and a little more touch latency issue...
    PUBG playback is similar to Oreo, Battery life also similar, calls,sms, volte, microphone, Video playback, YouTube, everything works fine..(haven't used Netflix/Amazon prime, don't have subscription)
    For those who are having issues once wipe everything in recovery (after taking backup), and if the issue present then also submit feedback in app with logs
  16. Sawan solanki
    Sawan solanki , Dec 18, 2018 :
    thanx for android 9 but it has lot of bugs please fix
    auto screen lock not working
    phone freeze
    camera stoped responding
  17. Yash Bhootra
    Eclair Dec 18, 2018
    Yash Bhootra , Dec 18, 2018 :
    I've this Netflix problem. can you please help me with it?
  18. bgpancha
    that's probably means they have implemented anti roll back feature, which I think google mandates for Google cts for pie
  19. Balachandran6
    Balachandran6 , Dec 18, 2018 :
    same problem bro
    any solution
  20. the_o2
    OnePlus 9 Series Expert Community Expert Dec 18, 2018
    the_o2 , Dec 18, 2018 :
    That's why it's called beta not stable, report the bugs in feedback section, no need to create threads about it.
    Joey463 likes this.
