744
OxygenOS Open Beta 22 for the OnePlus 5 and Open Beta 20 for OnePlus 5T
  1. niyas.mohammed
    Froyo Dec 19, 2018
    Ravi BINAVAT likes this.
  2. bhargavsoneji
    Cupcake Dec 19, 2018
    bhargavsoneji , Dec 19, 2018 :
    then how I update pie
  3. animaaryan
    Honeycomb Dec 19, 2018
    animaaryan , Dec 19, 2018 :
    If you're on Stable, search for Beta Pie update over OnePlus page. It'll be available in software updates itself. Download the package and apply through local upgrade to enter Pie path.
  4. G_pankaj_joshi_uyfo
    Eclair Dec 19, 2018
  5. Mr_Cyrox
    KitKat Dec 19, 2018
    Mr_Cyrox , Dec 19, 2018 :
    If you can't do basic search Open Beta is not for you...
    Currently Pie is not stable...
  6. MJ_Vikram
    KitKat Dec 19, 2018
    MJ_Vikram , Dec 19, 2018 :
    read the first post of this thread. if you don't understand then better stay away..
  7. MJ_Vikram
    KitKat Dec 19, 2018
  8. nvkiran1plus
    Ravi BINAVAT and F1517244994126 like this.
  9. PokiX
    Jelly Bean Dec 19, 2018
    PokiX , Dec 19, 2018 :
    I took some time to adapt a few scripts to plot battery stats and this is what I get:
    At 13:26 I plugged in the charger and in ten minutes it went from 57% to 72%.
    As you can see, input current to the battery (Charge-Discharge) gets lower (from 3.5A to 2A) when battery gets more and more charged.
    You might have a problem on your device, either hardware or software.
  10. _Stephanie_
    Froyo Dec 19, 2018
    _Stephanie_ , Dec 19, 2018 :
    It was working just fine before the update. The same bugs don't affect everybody.
  11. Aman_Swarnkar
    Aman_Swarnkar , Dec 19, 2018 :
    when it is realised in india because my 5t is not gat notification related the update of pie and i also check mannual but results are same.. your system is up to date.
    please resolve the same.
  12. sidharthdas
    sidharthdas , Dec 19, 2018 :
    Hi Everyone, I can't update Android 9, please suggest me how can I update Android Pie, I go to settings- system update but it shows you system is already up to date, please revert thanks
    Ravi BINAVAT and Q1522463113691 like this.
  13. Q1522463113691
  14. E1545241299793
  15. kartiksharma913
  16. Zeyobras
    Ravi BINAVAT and sidharthdas like this.
  17. DocTaher
    DocTaher , Dec 19, 2018 :
    Guys .... I'm still not able to find any updates on system update.... pls help
  18. H1545265626143
    Cupcake Dec 20, 2018
  19. chethan.setty
  20. D1514122836676
