744
OxygenOS Open Beta 22 for the OnePlus 5 and Open Beta 20 for OnePlus 5T
  1. Rohan_S_P
    Ice Cream Sandwich Dec 12, 2018
    Rohan_S_P , Dec 12, 2018 :
    my phone app not opening after pie update.
    I enable permission as mentioned then also phone app not working.
  2. dplusg
    Cupcake Dec 12, 2018
    dplusg , Dec 12, 2018 :
    so all of you are using a custom recovery to flash this zip?
  3. Srikar21
    Gingerbread Dec 12, 2018
    Srikar21 , Dec 12, 2018 :
    is playstore showing certified for you ?
  4. gowtham07
    Eclair Dec 12, 2018
    gowtham07 , Dec 12, 2018 :
    finally [e]1f603[/e][e]1f604[/e] waiting for stable update [e]1f603[/e][e]1f604[/e]
    B1528635709872 likes this.
  5. mahesh.silwal
    Eclair Dec 12, 2018
  6. F_Ankur_Detroja_
  7. pnivaskumar
    Eclair Dec 12, 2018
  8. Maghuro
    Honeycomb Dec 12, 2018
    Maghuro , Dec 12, 2018 :
    After update, and after clean all data from play store and Google play services, I can't update not install apps in play store.
    Also, I had VoLTE activated trought the tutorial on XDA. It doesn't work right now.
  9. saivenkatsingh
    Eclair Dec 12, 2018
  10. daster_x
    daster_x , Dec 12, 2018 :
    I put a screen shot - no message about non-certified... just nothing there.
    and I can update the apps
    gotshoaib likes this.
  11. yurdakul
    Eclair Dec 12, 2018
    yurdakul , Dec 12, 2018 :
    from open beta 19?
  12. Aswin08
    Aswin08 , Dec 12, 2018 :
    People with issues.
    Twrp error :
    Remove Compatibility.zip using Zarchiver and flash.
    Device not certified:
    If rooted, using magisk hide props module and use previous oreo device fingerprint certification.
    fcarmona likes this.
  13. F_Ankur_Detroja_
  14. Icecreamypie
  15. yurdakul
    Eclair Dec 12, 2018
    you can just update from 'System Updates'.
  16. tusSh.007
  17. MD1101
  18. shabs_88
    shabs_88 , Dec 12, 2018 :
    Would love to try it but the problem is I am already facing battery issues.... Using beta might drain more
  19. ale_zano
    Froyo Dec 12, 2018
    ale_zano , Dec 12, 2018 :
    My god my 5t is way faster, animations are amazing, apps open much faster and in a cooler way. Loving this update. Thank you all!
    gotshoaib and Mri2907 like this.
  20. F_Ankur_Detroja_
    F_Ankur_Detroja_ , Dec 12, 2018 :
    I don't think so.because it just open twrp
    Abin_123 likes this.
