744
OxygenOS Open Beta 22 for the OnePlus 5 and Open Beta 20 for OnePlus 5T
  1. Lunar73
    Eclair Dec 12, 2018
  2. Young_Blood
    KitKat Dec 12, 2018
  3. Aswin08
    Honeycomb Dec 12, 2018
    Aswin08 , Dec 12, 2018 :
    Read Pinned post. Adaptive brightness logic is changed in Pie by Google.
    ruchit.thakkar likes this.
  4. PokiX
    Jelly Bean Dec 12, 2018
    PokiX , Dec 12, 2018 :
    Confirmed, it's not present on their website.
    I downloaded beta19 and it detected an OTA for beta20 which is installing.
    Multi8ball and Bogo268 like this.
  5. Bogo268
    Gingerbread Dec 12, 2018
    Bogo268 , Dec 12, 2018 :
    No problem. Is far more important to give them feedback. Use another section.
  6. ombatijack
    Eclair Dec 12, 2018
    ombatijack , Dec 12, 2018 :
    i see. thanks!
  7. Ashok199107
    Eclair Dec 12, 2018
    Lunar73 likes this.
  8. noeljohnson10
    Donut Dec 12, 2018
    noeljohnson10 , Dec 12, 2018 :
    if you go to accessibility settings you can turn off animations. This makes the transitions much faster and smoother.
    Deactivated User likes this.
  9. MD1101
    MD1101 , Dec 12, 2018 :
    new gestures
    amitmathew likes this.
  10. shubhamgupta97
    Donut Dec 12, 2018
    Multi8ball likes this.
  11. veda2810
    veda2810 , Dec 12, 2018 :
    will this remove all data from phone ?.or only reset the system setting ......
  12. psycholyzern
    Froyo Dec 12, 2018
    psycholyzern , Dec 12, 2018 :
    Than
    Thanks. Really neat. I love it.
  13. ruchit.thakkar
    Cupcake Dec 12, 2018
    ruchit.thakkar , Dec 12, 2018 :
    Thanks buddy. that post surely did answer a lot of questions.
    Never Settle [e]270c[/e]️
  14. MD1101
    Take a backup of your data and then perform system settings reset from
    recovery (NOTE : Don't click on Erase Everything).
    It will just reset the system settings and the application data will be unaffected.
  15. yuvaankhanna50
    Eclair Dec 12, 2018
  16. Jish98
    Froyo Dec 12, 2018
    Jish98 , Dec 12, 2018 :
    There's no swipe up home navigation gesture like in the Oneplus 6/6T.
    0.o
    Although there's an option for that in the Button settings.
  17. bMbwambo
    Eclair Dec 12, 2018
  18. Ashok199107
    Eclair Dec 12, 2018
  19. C1521286768387
    Eclair Dec 12, 2018
    C1521286768387 , Dec 12, 2018 :
    I had the same issue. All I did to solve this problem was deleting OnePlus launcher on Google Play. Problem solved with no need to perform hard reset
  20. karthik yadawad
    Ice Cream Sandwich Dec 12, 2018
    karthik yadawad , Dec 12, 2018 :
    VivekMalipatel
    heyy Didi you get the Update?? But from Where did u?​
    Go to settings look for updates, if you are on beta os.
