744
OxygenOS Open Beta 22 for the OnePlus 5 and Open Beta 20 for OnePlus 5T
  1. bMbwambo
    Eclair Dec 12, 2018
  2. Ashok199107
    Eclair Dec 12, 2018
  3. C1521286768387
    Eclair Dec 12, 2018
    C1521286768387 , Dec 12, 2018 :
    I had the same issue. All I did to solve this problem was deleting OnePlus launcher on Google Play. Problem solved with no need to perform hard reset
  4. karthik yadawad
    Gingerbread Dec 12, 2018
    karthik yadawad , Dec 12, 2018 :
    VivekMalipatel
    heyy Didi you get the Update?? But from Where did u?​
    Go to settings look for updates, if you are on beta os.
  5. Nishchay Vaid
    Nishchay Vaid , Dec 12, 2018 :
    I tried rooting with Magisk 18.0 and it fails to pass safety net ! ( These guys were literally giving reasons that the open betas needs to pass safetynet , hence the delay )
    CTS Profile Check fails!!
    What in the hell is wrong with OnePlus ?!
    INFO : This build cannot be used as a daily driver cause your basic apps like Google Pay won't function due to SafetyNet not being passed.
    Just to Quote Mr @Manu J. words
    " Compatibility Test Suite(CTS) is just another step in a long process, before releasing a build we also need to make sure it is Google Play certified, and all this does take time to be processed and an ETA is not something we can promise cause there could be changes in release date due to one of this steps failing or getting delayed and various other factors related to QT "
    This wait was worthless!!
  6. JamesBoulder
    JamesBoulder , Dec 12, 2018 :
    I tried that.
    Didn't worked.
  7. rasulkhan7
    Froyo Dec 12, 2018
    rasulkhan7 , Dec 12, 2018 :
    So,
    The Oil Painting Effect still has no solution even after mentioning in the community ! they said they hear but wbt the response ?
    Multi8ball likes this.
  8. bMbwambo
    Eclair Dec 12, 2018
  9. LegolasX
    Jelly Bean Dec 12, 2018
    LegolasX , Dec 12, 2018 :
    solution to most issues are already given in pinned post in page no 1 including yours.
    Jish98 likes this.
  10. sridiculous
    sridiculous , Dec 12, 2018 :
    I was on H2OS Pie Beta and switched to OOS Pie Beta. TWRP by Siankatabg. The steps followed:
    1. Removed the fingerprint and security pin and changed to None.
    2. Downloaded the Beta Zip and modified it by removing the compatibility.zip.
    3. Reboot to recovery
    4. Wiped Dalvik + Cache
    5. Installed the Modified Zip + Magisk 18.0
    6. Wiped Dalvik + Cache just to be sure
    7. Reboot system
    No data loss and everything working as it should be.
    One strange thing I did notice however is that the Android Security Patch Level Shows as September 1, 2018. I thought this was supposed to be November 2018. Could it have been due to the dirty flash?
  11. ash_insiider
  12. Ashok199107
    Eclair Dec 12, 2018
  13. Arvind9118
    Froyo Dec 12, 2018
    Arvind9118 , Dec 12, 2018 :
    front portrait!! we got beta for portrait few months back and no stable till now.did you forget about it?
    G_Bruno_Oliveira_ioiY likes this.
  14. quickfever
    Eclair Dec 12, 2018
    quickfever , Dec 12, 2018 :
    Can you provide link for Open beta 20 Oxygen OS?
  15. IsaacHung
    Honeycomb Dec 12, 2018
    IsaacHung , Dec 12, 2018 :
    yes. and the space between the top row of apps and the status bar is big too (5t)
    crzfyr and Jish98 like this.
  16. robertoprubio
    Froyo Dec 12, 2018
    robertoprubio , Dec 12, 2018 :
    No pink dots matrix at lower light conditions?
    Thanks again
  17. bMbwambo
    Eclair Dec 12, 2018
  18. sridiculous
  19. Ashok199107
    Eclair Dec 12, 2018
  20. Ashok199107
    Eclair Dec 12, 2018
