744
OxygenOS Open Beta 22 for the OnePlus 5 and Open Beta 20 for OnePlus 5T
  1. Dhineshkaran
    Eclair Dec 12, 2018
  2. LegolasX
    Jelly Bean Dec 12, 2018
  3. im.ashish
    Honeycomb Dec 12, 2018
    im.ashish , Dec 12, 2018 :
    it's only available to pixel and Android one phones as of now ... and yes you can't download it via play store as " your device is can't completeble for this"
    but yes you can download it via apk mirror and use the same
    gowtham07 likes this.
  4. Chiran_OP5
    Chiran_OP5 , Dec 12, 2018 :
    Just did what you shared but still it's not working :(
  5. joni.kohvakka
    Eclair Dec 12, 2018
  6. F_Aviel_Amor_gBST
    Cupcake Dec 12, 2018
  7. jugal_15
    Eclair Dec 12, 2018
    jugal_15 , Dec 12, 2018 :
    Yeah, It doesn't allows more other than these on same page.
  8. Mr.Naz
  9. tejasacharya
    tejasacharya , Dec 12, 2018 :
    dual sim stopped working.. only 1 sim works which's data is enabled !!
    but then wiped cache from recovery and then good to go.
    i guess wiping cache from recovery solves half the issue after beta OTA !
  10. LegolasX
    LegolasX , Dec 12, 2018 :
    oh, no idea why its not allowing.
    it should be 3 rows by default.
  11. Ashok199107
    Eclair Dec 12, 2018
  12. Malhotra_H
  13. RATHEESH.A.V
    Froyo Dec 12, 2018
  14. im.ashish
    after trying pie in op5t for more then 8 hr+
    I've observed some point
    Volume slightly low (then oreo)
    Gesture not working fine( previously in oreo they are more frequently and fast)
    brightness not auto controlled ( better in oreo)
    Battery was improved then oreo
    Adaptive battery work's gud
    Parallel apps (like ola uber and more)
    Charging speed improve in pie
    new UI awsome
    it was just my observation I've also submitted feedback as gestures.. as I don't like these (in pie)
    and sound was bit low then oreo...
    Dhineshkaran likes this.
  15. P1544625195246
  16. RATHEESH.A.V
    Froyo Dec 12, 2018
    RATHEESH.A.V , Dec 12, 2018 :
    yes.. through stock recovery.. no data loss.. working fine.. I hv unlocked bootloader
  17. Krishks
    Froyo Dec 12, 2018
    Krishks , Dec 12, 2018 :
    Will this include the equaliser settings made available for Bluetooth headphones ?
  18. B1516039939883
    Eclair Dec 12, 2018
    B1516039939883 , Dec 12, 2018 :
    i have a question. i want to go from stable to beta. do i hv to flash OB 19 before flashing OB 20. or can i flash OB 20 directly from Stable 5.1.7
  19. P1544625195246
    P1544625195246 , Dec 12, 2018 :
    without unlocking boatloader can i flash it r no rply mee
  20. sanjeetgupta
