99
OxygenOS Open Beta 22 for the OnePlus 6 and Open Beta 14 for OnePlus 6T
  1. pranav_karakavalasa Donut Jul 11, 2019
  2. rroshanz Cupcake Jul 11, 2019
    rroshanz, Jul 11, 2019 :
    ofcourse its necessary
  3. praveen226 Cupcake Jul 11, 2019
  4. mohan8601 Cupcake Jul 11, 2019
  5. B_Wrath Marshmallow Jul 11, 2019
    B_Wrath, Jul 11, 2019 :
    As a beta tester, what have you done to rectify your issues?
    By reading the first post of this thread carefully and in it's entirety.
    Maverick2.0, Kytharsis and ironass like this.
  6. ironass KitKat Jul 11, 2019
  7. praveen226 Cupcake Jul 11, 2019
    praveen226, Jul 11, 2019 :
  8. ironass KitKat Jul 11, 2019
    ironass, Jul 11, 2019 :
    I can only see one teensy, weensy, flaw in the last post @B_Wrath :rolleyes:
    Looks like an I.D.TEN.T error. ;)
  9. T1539496809178 Cupcake Jul 11, 2019
    T1539496809178, Jul 11, 2019 :
    Please anyone can tell me as to what is ther new charging time of their one plus 6 phones after the update of 9.0.7. Im asking this because mine is getting surprisingly charged too fast...Please anyone tell me their full charge time their ONE PLUS 6 is taking.
  10. Kytharsis Marshmallow Jul 11, 2019
    Kytharsis, Jul 11, 2019 :
    Wrong thread. This is for the beta.
    ironass likes this.
  11. F_Evaldas_Matusevicius_e Donut Jul 11, 2019
    F_Evaldas_Matusevicius_e, Jul 11, 2019 :
    Can i go from 14 beta to 8 beta i wana check batery does it fault oneplus or me. Same apps same usage but it dont last me 2 days noway.. on beta 8 i have screenshots i get 8 h sot now max 6.
  12. ironass KitKat Jul 11, 2019
    Yes, it is possible to downgrade from Open Beta 14 to Open Beta 8. It depends on how competent and experienced a user you are and requires using the MSMDownloadTool, wiping your phone and installing 2 different firmwares.
    Alternatively, as I am easily getting 7-8 hours SoT with 26-30 hours battery life... you could just do a Factory Reset of your phone and a fresh install of your apps and settings to see if clearing out the detritus on your phone, helps.
    drl431 and Kytharsis like this.
  13. dr3wp Donut Jul 11, 2019
    dr3wp, Jul 11, 2019 :
    Still having tons of fingerprint issues. The dedicated bug link does not work as it just keeps saying "upload failed". I have sent an email to bughunters but no reply. Am I the only one with these fingerprint reader lag issues?
    ironass likes this.
  14. Saniubah75 Gingerbread Jul 11, 2019
  15. ROHITAUGUSTIN Cupcake Jul 11, 2019
  16. ironass KitKat Jul 11, 2019
    Lots of reasons but usually, either the app's cache has become corrupted or is incompatible with the new update and needs to be cleared or the app itself has not been correctly integrated in the update process and needs to be re-installed. If it is multiple apps, then do a backup and Factory Reset.
    Yannis Neris and Kytharsis like this.
  17. FrozenFantasy Cupcake Jul 11, 2019
  18. at0mixX Froyo Jul 11, 2019
    at0mixX, Jul 11, 2019 :
    Same here. Accidently called 911 emergency when randomly tapping the screen when it was blacked out. Had to force reboot to get the screen to come back on.
  19. G_Kirk_Fontaine_MBlG Eclair Jul 11, 2019
  20. drl431 KitKat Jul 11, 2019
    ironass and G_Kirk_Fontaine_MBlG like this.
