189
OxygenOS Open Beta 23 for the OnePlus 5 and Open Beta 21 for OnePlus 5T
  1. ReeSilva Donut Dec 20, 2018
  2. shubhamdsingh Froyo Dec 20, 2018
    shubhamdsingh, Dec 20, 2018 :
    i am facing this issue as well..
  3. Anand.jaganathan Eclair Dec 20, 2018
  4. T1545237463647 Cupcake Dec 20, 2018
    T1545237463647, Dec 20, 2018 :
    AbhishekS287
    Aah that's too much of effort. Are you sure that works though? If yes, then I'm sure he wouldn't mind doing that.​
    yeah I'm sure coz I did the same thing yesterday n it worked
  5. Rajesh Shiva Gingerbread Dec 20, 2018
    Rajesh Shiva, Dec 20, 2018 :
    its not a issue at all, if such thing happens again u can either choose to receive notification or Stop notification if its annoying....thats it
  6. shubhamdsingh Froyo Dec 20, 2018
    i understand and if I recollect it correctly it was introduced in Oreo. but the swipe was well defined. a swift swipe removed it and a slow one opened this menu of settings...
    Rajesh Shiva likes this.
  7. PokiX Jelly Bean Dec 20, 2018
    PokiX, Dec 20, 2018 :
    There's this thing in the middle of your mouse. With this you can scroll up and read other posts. Magic :p
    MPalmiro likes this.
  8. PokiX Jelly Bean Dec 20, 2018
    Probably a warning that you are going to beta release which is somehow a downgrade in terms of stability.
    Make sure to read previous posts to get a feeling of others problems and if you should install a beta.
  9. Rajesh Shiva Gingerbread Dec 20, 2018
    May be its Google choice to be like this from Pie or OnePlus custom feature, let us wait and see in the future updates..
    shubhamdsingh likes this.
  10. shanmugapandian Cupcake Dec 20, 2018
    shanmugapandian, Dec 20, 2018 :
    oxygen beta
  11. G_Sunil_Sathyanarayana_h Cupcake Dec 20, 2018
    K. Hille and mansch like this.
  12. Chitranshu24 Donut Dec 20, 2018
    Chitranshu24, Dec 20, 2018 :
    anyone facing issues with wifi win nee beta update ? m facing some issues whereby the wifi doesn't behave properly..it doesn't establish connection estatenly. i have to go to wifi settings and to tap network name to get the connectivity.
  13. AbhishekS287 US Brand Ambassador Dec 20, 2018
    AbhishekS287, Dec 20, 2018 :
    No, the text for that warning is different than this.
  14. tomeklives Froyo Dec 20, 2018
    tomeklives, Dec 20, 2018 :
    Is this on the newest update? So it wasn't fixed?
    Are you on T-Mobile?
  15. Cervantes Lollipop Moderator Dec 20, 2018
  16. G_Cameron_Cowen_kRsX Donut Dec 20, 2018
  17. micemty Gingerbread Dec 20, 2018
    mansch likes this.
  18. Yamil E. Donut Dec 20, 2018
    Yamil E., Dec 20, 2018 :
    I'm still have problems when I try to install or update apps from play store. They lock in "downloading..." and nothing happens.
  19. G_LEO_PAUL_HCRL Cupcake Dec 20, 2018
  20. bawng_upa Gingerbread Dec 20, 2018
    bawng_upa, Dec 20, 2018 :
    Silky smooth, good update. FS Gesture work perfect again.
    BTW, have you seen this TV Series guys? 'Bodyguard'
    Note: Please check the image carefully before you criticize my post.
