189
OxygenOS Open Beta 23 for the OnePlus 5 and Open Beta 21 for OnePlus 5T
  1. Cassoli_2017
    Donut Dec 20, 2018
    Cassoli_2017 , Dec 20, 2018 :
    Here it is extremely stable, I passed the ROM via adb sideload, I am without root. Working everything perfectly. Very happy here !!!
    PS: VoLTE activated and working perfectly!
    Rakshit_Patil likes this.
  2. salomao
    Donut Dec 20, 2018
    salomao , Dec 20, 2018 :
    I am on beta 21.
    When I receive a phone call I have to unlock my phone before I can know who is calling me and answer or decline it.
    I found that the problem is gonne when I remove the security options for my lock screen.
    If I set any security (pin, pattern, etc) then I need to unlock my phone before knowing who is calling and answer the call.
    How can I fix this?
  3. prabhatspatil@gm
    Gingerbread Dec 20, 2018
  4. Jairo_666
    Donut Dec 20, 2018
    Jairo_666 , Dec 20, 2018 :
    Everything's just as smooth as the first time I used this amaizing device, now even more. The only thing I can complain about is that the gestures aren't in the way this phone is. Sometimes when I get back to home screen, the reaction or gesture is not as smoothly as it supposed to be. Everything's else is just great, that's cool, even more when we're talking 'bout an open beta.
  5. G_dhananjai_rai_HWoE
    Froyo Dec 20, 2018
  6. pedronisio
    Donut Dec 21, 2018
    pedronisio , Dec 21, 2018 :
    4 times today. beta 23
  7. ZahidulNadim
    Eclair Dec 21, 2018
    ZahidulNadim , Dec 21, 2018 :
    wow! another beta update! looks like OP is serious to bring us stable very soon! waiting for that!
  8. Amit98674@
    Eclair Dec 21, 2018
  9. Yamil E.
    Donut Dec 21, 2018
    Yamil E. , Dec 21, 2018 :
    My problems with play store continue.
    Btw, just a suggestion, it's possible add a gesture to lock screen? Maybe a double tap in the notification bar or something like that...
    catatoa likes this.
  10. sotta
    Cupcake Dec 21, 2018
    sotta , Dec 21, 2018 :
    same here
  11. W1540689651364
  12. GehendraK
  13. AlloTomato
    Honeycomb Dec 21, 2018
    AlloTomato , Dec 21, 2018 :
    did a fresh installation of open beta 23 for OnePlus 5 , unable to use parallel apps, whenever I'm creating parallel app , its just creating the second icon in the app drawer.
    I wasn't able to login to two different accounts on both the parallel apps
  14. splus9
    Froyo Dec 21, 2018
    splus9 , Dec 21, 2018 :
    Hey OnePlus, this update is faulty, it has random reboots.
    Are you going to stop this update or fix it??? Do something.
  15. kalpak11
    kalpak11 , Dec 21, 2018 :
    Mi Band 2/3, Honor Band 4
    After updating to pie, I m not getting contacts names on my smart band whenever I get any call. if I try cutting the call from band the call doesn't even gets cut. please fix this issue
  16. I_am_Batman
    KitKat Dec 21, 2018
    I_am_Batman , Dec 21, 2018 :
    Oneplus 5/T has inbuilt call recorder. It's your country that has to support it so that OnePlus can allow it in your country.
  17. I_am_Batman
    KitKat Dec 21, 2018
    Reset everything didn't work?
  18. I_am_Batman
    KitKat Dec 21, 2018
    How did you do a fresh install?
    I mean, Did you install and reset or reset and then install?
  19. Harshag11
    Froyo Dec 21, 2018
    Harshag11 , Dec 21, 2018 :
    +1, I'm facing this issue too
  20. AlloTomato
    wiped everything from recovery and installed complete zip from the stock recovery
