189
OxygenOS Open Beta 23 for the OnePlus 5 and Open Beta 21 for OnePlus 5T
  1. joncharmed93 Froyo Dec 23, 2018
    joncharmed93, Dec 23, 2018 :
    Are you trolling? You don't think I know what beta's are? The fix will roll out to the next beta update when the testing is completed. Then when OP sees that most of the issues are fixed then the stable will roll out. Stop acting like you know it all when you don't.
    PokiX likes this.
  2. zer0se7en Honeycomb Dec 23, 2018
    zer0se7en, Dec 23, 2018 :
    Did I say you? OMG. Yes I don't know it all. Yet I'm not the one facing problems. And I'm the one posting solutions on how to fix those problems.
    Keep it simple, man. Do what you said earlier. Do not waste your time with me. Bye!
  3. joncharmed93 Froyo Dec 23, 2018
    Well I have the reboot issue and your claiming that everyone with the reboot issue just didn't load the beat correctly and don't know how betas work. So you did include me and many others. Don't try to claim that everyone is doing something wrong just because your one of the few who don't have problems. We don't know what is causing the reboot issue, but it is effecting the OP5/T and the latest OP6 beta. So please just stop assuming and claiming that we are the problem when clearly the beta has the problem.
    Then we won't have a problem.
  4. zer0se7en Honeycomb Dec 23, 2018
    Dude, seriously... Just do what you just said earlier. man oh man.
  5. joncharmed93 Froyo Dec 23, 2018
    zer0se7en
    Dude, seriously... Just do what you just said earlier. man oh man.​
    I will just making sure I get the point across
  6. zer0se7en Honeycomb Dec 23, 2018
    ??? If you have nothing more to contribute, just stop, man.
  7. Sid_Ck Ice Cream Sandwich Dec 23, 2018
    Sid_Ck, Dec 23, 2018 :
    Agreed I did load the beta in a way similar as you mentioned no reboot issues etc here too.
    Betas are not as simple as it's looks!
    zer0se7en likes this.
  8. zer0se7en Honeycomb Dec 23, 2018
    Yes they aren't. Yet some are always playing the blaming game and not look upon themselves if they too made a mistake or error. It's always the devs fault for them.
    There is always a workaround even if the better solution will be released by OnePlus.
  9. joncharmed93 Froyo Dec 23, 2018
    I'll take confirmation bias for 200 Alex.
  10. Goeb76 Cupcake Dec 23, 2018
    Goeb76, Dec 23, 2018 :
    my Phone reboots every two or three hours. Selfie cam keeps making photo's, had to turn of smile recognition.
    Anyone else?
  11. feernando997 Froyo Dec 23, 2018
    feernando997, Dec 23, 2018 :
    Olá, boa noite. Gostaria de reportar outro possível bug, ocorreu duas vezes seguidas. É a opção de gesto que atende a chamada ao elevar o aparelho até a orelha. Essa opção está entrando em conflito com a função de bloquear a tela para o aparelho não mexer sozinho no bolso por acidente. Não entendi bem ainda pois não sei se é um bug, afinal hora acontece isso, hora não acontece.. Enfim obrigado!
  12. alexanderphoenix Cupcake Dec 23, 2018
    alexanderphoenix, Dec 23, 2018 :
    Hi, first time poster on this forum!
    I've played around with installing custom ROMs in the past, however when I bought the OnePlus 5T I decided to keep it on stock.
    Now I'm kinda itching to test Android 9.0 Pie and from what I'm reading the open beta is good enough to be my daily driver.
    So I went to download it tonight and upon installing it via the "Local Upgrade" method I was greeted by the following message:
    The package you selected is earlier than the current version. This may lead to failure to boot due to data compatibility issues. Are you sure you want to install the old version?
    Screenshot:
    Obviously I cancelled the operation.
    To make a long story short, I triple checked that I downloaded the right file, which I did, and I checked the MD5 checksum (on my computer and on my phone) and it doesn't match what's on the download page (see screenshots below).
    Has anyone encountered that message before? Is it safe to ignore?
    Had the MD5 matched, I'd have probably carried on with the upgrade, but I can't risk bricking my phone over something like this.
    Cheers,
    Alex
  13. sam311 Honeycomb Dec 24, 2018
    sam311, Dec 24, 2018 :
    Manu created a hidden post on Friday....there is also another hidden post created also
    Two hidden posts let's hope sth is big is coming for OnePlus 5T
    Hope stable
    Assumption
  14. tomeklives Froyo Dec 24, 2018
    tomeklives, Dec 24, 2018 :
    me too bro. random reboots.
    feernando997 likes this.
  15. zer0se7en Honeycomb Dec 24, 2018
    zer0se7en, Dec 24, 2018 :
    I did not encounter that as I never liked the Local Update method. Actually I also almost never check the checksum info.
    What version does your device have now? Do you have your bootloader unlocked? Are you willing to reset to Factory format?
    Do you already have the ADB files needed on your computer?
    Sorry for all the questions. We need that for me to be able to help.
    Also need to know, what computer you use? If you are on Mac, I could def help you. If not, sorry. I can only give the line commands needed for the process. It's been a long time since I've used Windows.
  16. i_am_tamil Froyo Dec 24, 2018
    i_am_tamil, Dec 24, 2018 :
    in gaming mode pls block all third party apps call like whats app Instagram Facebook pls add this feature upcoming update
  17. Hebbnag Gingerbread Dec 24, 2018
    Hebbnag, Dec 24, 2018 :
    it will b another beta release for 5/5t.
  18. alavala.mahesh01 Cupcake Dec 24, 2018
    alavala.mahesh01, Dec 24, 2018 :
    some of the observations after android update:
    alarm sound is not coming.
    phone is getting stuck continuously
    phone is ringing but call is coming after sometime
    sometimes not able to reduce volume using keys
    Navigation from one screen to another screen is taking long time.
    most of the time apps are asking me to close
    Josemartin1& and arpit1+ like this.
  19. G_Harish_Chandra_XAJZ Froyo Dec 24, 2018
    G_Harish_Chandra_XAJZ, Dec 24, 2018 :
    I was using stable update upto last week but this week I updated for beta update of one plus 5 beta 23, after this phone is restarting suddenly after some hours, about 5-6 times a day. please correct this issue in future beta update
  20. Mohan k7 Cupcake Dec 24, 2018
    Mohan k7, Dec 24, 2018 :
    unable to connect any Bluetooth devices (op bulkets wireless, snartwatches). Is there any fix?
