172
OxygenOS Open Beta 24 for the OnePlus 5 and Open Beta 22 for OnePlus 5T
  1. manojyarashi
    Froyo Dec 26, 2018
    manojyarashi , Dec 26, 2018 :
    Netflix still not working even after mentioned in the changelog....
    when I first updated to OB22 the issue started and then reverted back to OB21 (OREO) so everything was fine and working, today I upgraded to OB24 after reading the positive reviews but still Netflix doesn't work over WiFi as before, only works on mobile data 4g or LTE (SAME AS OB22)....And before you guys start about clearing cache, that already I have done it....
  2. G_harmeet_singh_NqKT
    Cupcake Dec 26, 2018
  3. lucifer3036
    Froyo Dec 26, 2018
    lucifer3036 , Dec 26, 2018 :
    You must be having unlocked bootloader.
  4. G_harmeet_singh_NqKT
  5. G_harmeet_singh_NqKT
    G_harmeet_singh_NqKT , Dec 26, 2018 :
    not received update till today, someone told me to unlocked bootloader , I did that also, but it doesn't work.
    no updates arrived.
    kindly suggest.
  6. G_harmeet_singh_NqKT
  7. lucifer3036
    Froyo Dec 26, 2018
    Sorry for my confusing language in previous post. To clarify, if you have unlocked bootloader you will be asked to download full rom and if you have locked bootloader you will get incremental OTA.
  8. krish13796
    krish13796 , Dec 26, 2018 :
    in OnePlus launcher 3.1.5 which we have in OnePlus 5 ( open beta 24 ) there is a delay when we press back button multiple times to close app and go on home screen. after looking closely i found that if we hold back button on home screen then launcher is doing something weird stuff that is delaying the next task.
    1st one is normal home screen which is ready for input and 2nd one is the screen when we keep pressing back button fast to go home and then the screen is not ready for input. it takes 1 second delay after we stop pressing back button to get ready for input.
  9. C1544629534000
    Donut Dec 26, 2018
    kulthe25 likes this.
  10. G_harmeet_singh_NqKT
    OK friend, thanks for your suggestion I disable unlocked bootloader.
  11. krish13796
    and where is HDR mode?
  12. kulthe25
    kulthe25 , Dec 26, 2018 :
    camera shutter sound still continues even if it made it off from setting in one plus 5t
  13. Rajat_arora_
    Gingerbread Dec 26, 2018
    F_Michael_Robert_HIiq likes this.
  14. krish13796
    same issue in OnePlus 5
  15. ashreddy
    Donut Dec 26, 2018
    ashreddy , Dec 26, 2018 :
    Hi.
    Reported bugs for OnePlus 5 open beta 22 and 23. Regarding camera shutter sound and music volume works in home page when music isn't playing. Please fix this.
    Thanks.
  16. X1527693372201
  17. krish13796
    they changed the volume button default functionality to change media volume and not the notification volume. this is not a bug it is android 9 feature
    K1518454701936 likes this.
  18. C1544629534000
    Donut Dec 26, 2018
  19. krish13796
  20. Abhig11
    Donut Dec 26, 2018
