172
OxygenOS Open Beta 24 for the OnePlus 5 and Open Beta 22 for OnePlus 5T
  1. drmvsrinivas
    Gingerbread Dec 26, 2018
    drmvsrinivas , Dec 26, 2018 :
    Equalizer settings in tuner also issue.while adjusting changes in sound not possible but if you off it and on it then you can see the changes. Test all once
  2. X1536819789971
    Donut Dec 26, 2018
  3. X1536819789971
    Donut Dec 26, 2018
  4. Johnson7335
    Donut Dec 26, 2018
  5. N1545661440683
    Donut Dec 26, 2018
  6. N1545661440683
    Donut Dec 26, 2018
  7. animaaryan
    Honeycomb Dec 26, 2018
    animaaryan , Dec 26, 2018 :
    Do y'all take time to read the change logs of Pie Update over devices itself?
    The auto brightness is a Google Adaptive functionality that uses input from user depending on how he uses the percent of brightness in different situations. The AI learns and then changes brightness according to how you want it in different places, lighting and areas.
  8. animaaryan
    I remember doing a Clear Application and Data Cache or something in recovery mode and it's been solved ever since.
    Note You may lose all the applications but not data. This is not a Factory Reset, but a Device Reset. You'll need to reinstall all applications as it'll clear data as well as cache but not the Internal Storage.
  9. animaaryan
    The issue still persists?
    Please make a complete report with logs and send it to Bug Hunters. It may affect other devices over time and create a rush in this thread.
  10. animaaryan
    Keep on waiting..
  11. Deactivated User
    Dec 26, 2018
  12. E1516811955102
    Cupcake Dec 26, 2018
  13. Parameshwar2306
    Parameshwar2306 , Dec 26, 2018 :
    Hello All,
    Recent apps switcher is still vertical stack even after updating oneplus 5 to open beta 24.. is anyone else facing the same??
  14. Voyager03
    Eclair Dec 26, 2018
    Voyager03 , Dec 26, 2018 :
    For those impatient for the update, try installing the excellent 'Oxygen Updater' (from the Play Store).
    I've been able to install the update with no problems using it.
    Everything seems to be working fine (been using it for a whole hour!)
  15. tropazr
    Froyo Dec 26, 2018
    tropazr , Dec 26, 2018 :
    Is anyone having issues with Google Assistant? I keep getting this black overlay screen after using the assistant shortcut app. I will do what it says and say "Ok Google" and it will give me results as normal but all future searches are wonky and unreliable. Its really hard to explain exactly what it's doing but it's not working correctly. Any help is appreciated.
  16. angourakis
    Froyo Dec 26, 2018
    angourakis , Dec 26, 2018 :
    If you use OnePlus launcher, update it to the latest version on Play Store and clear data.
    I'm using Nova launcher and the recents from pie is working perfectly too
  17. syed8986thousif
  18. Parameshwar2306
    yeah, it works.. thank you [e]1f60a[/e]
  19. APhaniSankara
  20. Prashant kumar sangwan
