172
OxygenOS Open Beta 24 for the OnePlus 5 and Open Beta 22 for OnePlus 5T
  1. Mr_Cyrox
    KitKat Dec 27, 2018
    Mr_Cyrox , Dec 27, 2018 :
    Uninstall the launcher and reinstall it
  2. dapoaa
    Cupcake Dec 27, 2018
  3. Anonymous Fox
    Honeycomb Dec 27, 2018
    Anonymous Fox , Dec 27, 2018 :
    We can't uninstall the default OnePlus launcher
  4. Mr_Cyrox
    KitKat Dec 27, 2018
    Huh
  5. Anonymous Fox
  6. Anonymous Fox
  7. Mr_Cyrox
    KitKat Dec 27, 2018
    Glad it worked ;)
  8. a123lad
    a123lad , Dec 27, 2018 :
    After updating to pie on one plus 5, Netflix not working. Even after uninstall ing, trying to reinstall, not able to install
  9. Patxi T
    Patxi T , Dec 27, 2018 :
    Hello, It is not posible to syncronize with my Garmin Fénix 2 since the update.
  10. Pierre02
    Pierre02 , Dec 27, 2018 :
    They fixed this in beta 23/21
  11. SiddharthBokaria
    Gingerbread Dec 27, 2018
    SiddharthBokaria , Dec 27, 2018 :
    Hi, anyone using the OnePlus Bullet Type C earphones??
    I have been facing an issue with them since the pie update. Everytime I'm on a call, the audio on both ends suddenly drops, as in I am unable to hear what the other person is saying and neither do they receive any sound from my end. II have noticed it happens almost 90% of the cases. Only way to fix it is to disconnect the earphone and then again reconnect them. But usually it's kind of pissing off and the other party usually end up disconnecting the call (seems very rude to the other person right if the call suddenly stops)
    I have been trying to report this through feedback but sadly either the log sizes crosses the limit or the call drop issue doesn't happen when I'm trying to log it.
    I hope this is looked at since the earphones are proprietary to OnePlus and if they have issues with the phone then it looks pretty gloomy.
  12. bawng_upa
    bawng_upa , Dec 27, 2018 :
    The New Nav gesture is good, fast but it took very large part of the screen. Will be useful if we can edit this feature like its transparency, make it small or reduce its height.
  13. yusufefl
    Eclair Dec 27, 2018
    yusufefl , Dec 27, 2018 :
    After the update the auto brightness button isn't working. I change the brightness and hit the auto adjust icon from the drop down menu but no changes. just for your consideration developer brothers
  14. Pierre02
    It works for me. Try to perform a wipe cache
  15. bawng_upa
  16. yusufefl
    Eclair Dec 27, 2018
    how to do that? from boot menu? can u remind me I forgot how to enter that part.
  17. Pierre02
    Watch this. If recovery asks you some passwords/patterns, put your lock screen password/pattern/pin
  18. yusufefl
    Eclair Dec 27, 2018
    alright. just a restart did it. some crazy stuff and bottlenecks might happen during the long uptimes. :) thank btw.
  19. anksjdhv
    Froyo Dec 27, 2018
    anksjdhv , Dec 27, 2018 :
    Same here
  20. Mr_Cyrox
    KitKat Dec 27, 2018
    Did you read?
    I posted a solution to the same guy you quoted...
    anksjdhv likes this.
