172
OxygenOS Open Beta 24 for the OnePlus 5 and Open Beta 22 for OnePlus 5T
  1. anksjdhv
    Froyo Dec 27, 2018
    anksjdhv , Dec 27, 2018 :
    I can see it's working.. but this is stuck at uninstalling now..
  2. Mr_Cyrox
    KitKat Dec 27, 2018
    Mr_Cyrox , Dec 27, 2018 :
    Give it some time
    If it takes 3 or more minutes reboot the phone and try again
    anksjdhv likes this.
  3. anksjdhv
    Froyo Dec 27, 2018
    Thanks a lot! You solved my main problem!
  4. Mr_Cyrox
    KitKat Dec 27, 2018
    Glad it worked :)
  5. jazzyjff
    Gingerbread Dec 27, 2018
    jazzyjff , Dec 27, 2018 :
    I'm still having voicemail issues on T-mobile. Is anyone else having issues with an inability to get visual voicemail to register?
  6. marcolai147
    Cupcake Dec 27, 2018
  7. castaway
    Froyo Dec 27, 2018
    castaway , Dec 27, 2018 :
    often when i try to swipe to dismiss notification it keep showing notification menu for "stop notifications" and "keep showing" its annoying to me.Anyone else?
    BTW wifi tethering default AP name is set to "OnePlus3T"
  8. Mr_Cyrox
    KitKat Dec 27, 2018
    Once you chose it once or twice it shouldn't show up any more...
    Well it is the case for me at least...
    castaway likes this.
  9. Pierre02
    Honeycomb Dec 27, 2018
    Pierre02 , Dec 27, 2018 :
    Sometimes happened to me. I tapped keep showing
  10. S1509529097972
    Donut Dec 28, 2018
  11. S1509529097972
    Donut Dec 28, 2018
  12. G_siva_balaji_Zuvj
    Honeycomb Dec 28, 2018
  13. SoumyaMahunt
    Gingerbread Dec 28, 2018
  14. sourav shah
    Cupcake Dec 28, 2018
  15. Rotten Egg
    Rotten Egg , Dec 28, 2018 :
    Clear Cache,back up your data,do a factory reset and install full ROM.This might solve your problem.It works for me.(I am in OP5T Open beta 22). If confuse,take an expert advice before doing the process.
  16. sourav shah
    sourav shah , Dec 28, 2018 :
    Or should I turn back to stable update
  17. Rotten Egg
    For me,beta version is working well.So I didn't revert back to stable. You can revert back to stable ....follow the required procedure for safety.
  18. Rotten Egg
    This video might help u in understanding the process:
    sourav shah likes this.
  19. sourav shah
  20. Ajiteshmadai
    Eclair Dec 28, 2018
    Ajiteshmadai , Dec 28, 2018 :
    I am still on beta 24 for oneplus 5, assuming the stable update is same as the last beta update. Isnt it?
    I am still facing issues where the phone is getting shut down randomly. Happened twice when i left my phone away, then i check the phone it was powered off for no reason. The battery was beyond 50% in both scenarios,. Anyone else facing this issue?
