172
OxygenOS Open Beta 24 for the OnePlus 5 and Open Beta 22 for OnePlus 5T
  1. Obmann76
    Gingerbread Dec 28, 2018
    Obmann76 , Dec 28, 2018 :
    I have also problems with the connection stability with my Pebble. Maybe turning off battery optimisation for the Garmin app helps. Did help for a few hours for my Pebble time steel. But now it's disconnecting and reconnecting from time to time. I think this isn't a Pie problem, because it happened since one of the Oreo betas for the first time to me.
  2. G_g_ds_SGPo
    Cupcake Dec 28, 2018
    G_g_ds_SGPo , Dec 28, 2018 :
    is there any chance to make the clock to appear on the middle of the status bar? on op5t there's no notch(thank God!) but there is no option to change the location!
    B1541091037078 likes this.
  3. B1541091037078
  4. jays88
    jays88 , Dec 28, 2018 :
    only in H2OS
  5. SoumyaMahunt
  6. jays88
    when I flash to H2OS pie I got the nightscape, after I flash back OOS pie I can't get the nightscape.
  7. danvxz
    Honeycomb Dec 28, 2018
    danvxz , Dec 28, 2018 :
    does anyone know how to COMPLETELY disable gaming mode? I don't need it and it's extremely annoying, it keeps adding games to its list even if I remove the games, a week later something it's back on the gaming mode list again.
  8. daster_x
    daster_x , Dec 28, 2018 :
    check if you have any app in the below app list... if yes, when you launch it, Game mode is starting automatically.
  9. B1541091037078
  10. danvxz
    I know how gaming mode works, I just want to disable it completely. Whenever I add a game I have to go to settings and remove it from the list, which is annoying considering gaming mode is a feature I don't need nor use
    RoyxD4 and daster_x like this.
  11. Mr_Cyrox
    KitKat Dec 28, 2018
    Mr_Cyrox , Dec 28, 2018 :
    Why wouldn't you want game mode?
    I'm assuming you don't play heavy games to benifit from game mode...
  12. Nitin shokeen
    Eclair Dec 28, 2018
    Nitin shokeen , Dec 28, 2018 :
    performance is not as smooth as it was in Oreo sometimes screen get stuck on same page for a while,app do not respond smoothly, camera takes time to open and sometimes with black screen.
    RoyxD4 likes this.
  13. G_Viru
    Jelly Bean Dec 28, 2018
  14. K1525456996702
  15. Mr_Cyrox
    KitKat Dec 28, 2018
    Only two things that comes to mind is:
    Copying text from recents menu,
    Audio tuner for wireless/Type-C headphones/earphones
    UmairBhayat likes this.
  16. G_Viru
  17. G_Viru
    G_Viru , Dec 28, 2018 :
    and digital well being
  18. G_Viru
    Mr_Cyrox likes this.
  19. Mr_Cyrox
    KitKat Dec 28, 2018
  20. K1525456996702
