172
OxygenOS Open Beta 24 for the OnePlus 5 and Open Beta 22 for OnePlus 5T
  1. Ajay0
    Donut Dec 29, 2018
    gotshoaib likes this.
  2. Rotten Egg
    Honeycomb Dec 29, 2018
    Rotten Egg , Dec 29, 2018 :
    Now OP is releasing updates very fast for all range of its products.Hope 25/23 open beta for 5/T with improved camera very soon.
    H1534567923787 likes this.
  3. nikhilendrapratap
    Gingerbread Dec 29, 2018
    nikhilendrapratap , Dec 29, 2018 :
    Anyone with this issue?
  4. NavinThomsy
    Froyo Dec 29, 2018
    NavinThomsy , Dec 29, 2018 :
    Is anyone's music playing randomly when the alert slider is kept in "Ring" mode?
    Im on OB 24, rooted, unlocked. (Clean Flashed)
    I had this issue on OB 23 too. So I don't know what's causing this. I uninstalled my music app if that was the case but it seems that isn't the issue.
    Can any one confirm if this is a bug?
  5. Pierre02
    Pierre02 , Dec 29, 2018 :
    I am stock and locked. I don't have this issue
    Everley likes this.
  6. I_am_Batman
    KitKat Dec 29, 2018
    I_am_Batman , Dec 29, 2018 :
    Why are you in beta then? Go to stable.
    What do you even know about beta?
    Everley and HalCapone like this.
  7. swidnik0
    Donut Dec 29, 2018
    swidnik0 , Dec 29, 2018 :
    On the latest beta for OP5t ui is lagging after some time of using the phone.
    Rajesh Shiva likes this.
  8. robertoprubio
    robertoprubio , Dec 29, 2018 :
    OP5/5T cameras will be *never* improved, IMO
    RoyxD4 and HalCapone like this.
  9. KL5976
    Cupcake Dec 29, 2018
    KL5976 , Dec 29, 2018 :
    since the last update, the camera don't work.
    Anyone has the same issue ?
    Have re-install properly and wipe the cache...
  10. HalCapone
    HalCapone , Dec 29, 2018 :
    Said this today to.
  11. PokiX
    Jelly Bean Dec 29, 2018
    PokiX , Dec 29, 2018 :
    Rather the opposite.
  12. robertoprubio
  13. robertoprubio
  14. Mayurpatil155
    Froyo Dec 29, 2018
    Mayurpatil155 , Dec 29, 2018 :
    I've started facing a weird issue like even after enabling gaming mode I get notifications on my screen.
    When the device is on vibrate or silent mode the camera shutter sound and screenshot sound does not gets off.
    The notification panel lags most of the time while sliding down.
    Anyone facing the same problem?
  15. Mayurpatil155
    Froyo Dec 29, 2018
    robertoprubio
    Do you know if record calls apps are working with this rom?​
    There's an option to record calls you can use it manually for specific call or automatically for every call and yes it does works
  16. mprodromou
  17. Aziz_Amin_Oneplus
    Aziz_Amin_Oneplus , Dec 29, 2018 :
    Move to Stable version of Android Pie 9.0 if you or anyone is having issues on the beta version of Android Pie.
  18. PokiX
    Frequent reboots in standby are corrected on the last beta.
    Juan_Ma likes this.
  19. Juan_Ma
    Juan_Ma , Dec 29, 2018 :
    Hello, I'm having trouble with pinch to zoom in YouTube, is this happening to someone else?
    I've tried reinstalling the app, the problem is apparently solved but it happens again after a few hours.
  20. shaikhisa39
    Eclair Dec 29, 2018
    shaikhisa39 , Dec 29, 2018 :
    For Those who are using pie update and facing problem pls do a factory reset and backup Ur data my recommendation to do a factory reset after installation .. Bcz I was facing issues after updating to pie cell gets hang .. again and again and my negation button was not working .. after factory reset it's works flawlessly ..
