172
OxygenOS Open Beta 24 for the OnePlus 5 and Open Beta 22 for OnePlus 5T
  1. robertoprubio
    Gingerbread Dec 30, 2018
    robertoprubio , Dec 30, 2018 :
    In Android 8 I'm using ACR but isn't working fine on Android 9 (doesn't record), due to that I've asking for the stock recording...
  2. ravikrcsia
    nitinyadavyo likes this.
  3. Mayurpatil155
    Froyo Dec 30, 2018
    Mayurpatil155 , Dec 30, 2018 :
    Well then try some other app, ACR might not support the 9.0 OOS
  4. Harshag11
    Froyo Dec 30, 2018
    Harshag11 , Dec 30, 2018 :
    sure
  5. wahaz
    Honeycomb Dec 30, 2018
    wahaz , Dec 30, 2018 :
    They have one more day to prove me wrong... Stable release for the masses in 2019? I think so...
  6. orophim
    Froyo Dec 30, 2018
  7. robertoprubio
    In fact Android 9 isn't supporting record calls. ACR and others are not working well with PIE and the ones that are working are using root methods.
    Due to that I prefer the stock record calls app if possible.
    Really I don't understand WHY Oneplus is using region blocks :(
    EDIT: Finally I have enabled native record call following this tutorial: https://forum.xda-developers.com/oneplus-5/themes/app-enable-call-recording-boot-t3634292
  8. Mr_Cyrox
    KitKat Dec 30, 2018
    Mr_Cyrox , Dec 30, 2018 :
    Q. Why my Fingerprint does not work, after my phone is in standby for long time?
    A: The Fingerprint service goes to sleep and thus doesn't allow unlocking the phone.
    To avoid this, the current work-around it to turn Off Standby Optimization in Advanced Optimization Battery Settings or wake up the phone using Power button after long standby.
  9. Q1545979886501
    Cupcake Dec 30, 2018
  10. suryaraya
    Froyo Dec 30, 2018
    suryaraya , Dec 30, 2018 :
    take a screenshot of the ur version
  11. Q1545979886501
  12. Spannaa
    KitKat Dec 30, 2018
    Spannaa , Dec 30, 2018 :
    And you're not going to get Open Beta 24 if you're on OOS stable 5.1.7 :rolleyes:
    Try reading and searching before posting next time - you'd have found your answer and you wouldn't look so lazy and/or dumb...
    kazecs likes this.
  13. gorneanu
  14. Q1545979886501
    Q1545979886501 , Dec 30, 2018 :
    so I won't get the pie update???
  15. Jairo_666
    Donut Dec 30, 2018
    Jairo_666 , Dec 30, 2018 :
    I've been facing what it seems to be a bug when I scroll up and down, even when I open the apps box, my 5T react pretty slow. That happened four or five times since the last beta so I had to reboot the phone. it's really annoying that kind of things in a phone that usually works super fast and smooth.
  16. BrainsCollector
    BrainsCollector , Dec 30, 2018 :
    The best battery performance since first month of use Screenshot_20181230-164909.jpg Screenshot_20181230-164913.jpg
    And it was not even 100% charged, just 92%, so it would be almost 30% right now with 7:30h sot
  17. gorneanu
    gorneanu , Dec 30, 2018 :
    This beta might be the new 9.0.1 which will be the first Android Pie update for most of the users. It is official that 9.0.0 has been rolled back globally which means most of us don't get Android Pie for another week or more. Please give the required feedback on the beta so the people at OnePlus can release it into a stable 9.0.1 for everybody sooner. Thank you.
  18. Aziz_Amin_Oneplus
    Jelly Bean Dec 30, 2018
    Aziz_Amin_Oneplus , Dec 30, 2018 :
    9.0 hasn't roll back.
  19. gorneanu
    Your colleagues from customer service said so. I'm sorry I have not kept the transcript. They said I should wait for the next update not 9.0.0.
  20. Aziz_Amin_Oneplus
    So they must be concern with you not for the other customers, it's their choice to wait or download the current update.
