172
OxygenOS Open Beta 24 for the OnePlus 5 and Open Beta 22 for OnePlus 5T
  1. Rajiv_Chaube
    Cupcake Jan 2, 2019
    Rajiv_Chaube , Jan 2, 2019 :
    Anybody else getting Random crashes and phone freezing with pie in one plus 5t. It is really annoying as the phone was working like a beast with Oreo. However i am happy that the os has been upgraded to pie. I just want to highlight the issue that i am facing.
    vaibzbhardwaj likes this.
  2. PrismereKnight
    Donut Jan 2, 2019
    PrismereKnight , Jan 2, 2019 :
    Same problem here
  3. AkshSuri
    Cupcake Jan 2, 2019
    AkshSuri , Jan 2, 2019 :
    I have updated my OnePlus 5 to OS 9.0.0. After the update i am facing some serious issues with my mobile. The applications are crashing a lot and the battery is draining too fast like Flash. It drained to 30% from 70% in 4 hours with very little usage on 4G network.
    Also the major issues that i am facing are : -
    1. The phone freezes alot and had to restart else it won't work at all. I had to hold power button for some seconds and then after 10-15 sec the power options comes up. But during the freeze time i am unable to see any screen except the black screen.
    2. Facing issues with the wired earphones. The mic doesn't work many times and then i have to reinsert the cord to enable it. Also, the WhatsApp calls get disconnected saying that there is issue with the mic and Google Duo calls doesnt work.on voice at all. But works well when i am on normal call throught my phone. Infact the earphone mic doesn't work on PUBG game as well.
  4. Rajiv_Chaube
    Cupcake Jan 2, 2019
  5. Rajiv_Chaube
    Cupcake Jan 2, 2019
    Same issues of freezes
  6. Romak_99
    Eclair Jan 2, 2019
    Romak_99 , Jan 2, 2019 :
    I want to roll back to the stable channel on my 5T. Do I need to go back to the OTA on which Treble was released or I can flash to the update of OOS 9.0.0...the stable first update of Pie ROM.
  7. Jillala_Sravan
    Gingerbread Jan 2, 2019
  8. G_Viru
    Jelly Bean Jan 2, 2019
  9. abhishek_x1
    Eclair Jan 2, 2019
    RoyxD4 likes this.
  10. G.Andrea
    Froyo Jan 2, 2019
    G.Andrea , Jan 2, 2019 :
    When Google will release it for non-pixel devices
  11. daster_x
    daster_x , Jan 2, 2019 :
    hello. please use another thread for posting this. here it is all about Open Beta 24/22 (for 5/5t)
  12. Lethaljoe
    Honeycomb Jan 2, 2019
    Lethaljoe , Jan 2, 2019 :
    How long does it usually take for OnePlus to upload the latest stable build on their support website? I want to flash the stable release. I've tried flashing 5.1.7 but it says I can't downgrade. Any help would be appreciated.
  13. Dextro_619
  14. AkshSuri
    Cupcake Jan 2, 2019
    My phone is running.on open beta only
  15. daster_x
    in this case you need to write which version Open Beta you have installed. when you write "installed 9.0", it sounds more like stable version...
  16. AkshSuri
    Cupcake Jan 2, 2019
    alright, my.phone is running on open beta 5
  17. Mr_Cyrox
    KitKat Jan 2, 2019
    Mr_Cyrox , Jan 2, 2019 :
    Really?
    If so you would be on Oreo currently
    Post a screenshot from "About Phone" screen in settings
  18. AkshSuri
    Cupcake Jan 2, 2019
    Here is the screenshot
  19. Mr_Cyrox
    KitKat Jan 2, 2019
    Then why did you say you're on Open Beta 5?
    You're clearly using a OnePlus 5 with Open Beta 24 installed...
    A typo maybe?
  20. AkshSuri
    Cupcake Jan 2, 2019
    i have mentioned that in the above replies. It was a typo before
