172
OxygenOS Open Beta 24 for the OnePlus 5 and Open Beta 22 for OnePlus 5T
  1. K1546538108485
    Cupcake Jan 3, 2019
  2. iSkaL72
    Cupcake Jan 3, 2019
    syamkg12345 likes this.
  3. daster_x
    Gingerbread Jan 3, 2019
    daster_x , Jan 3, 2019 :
    from what I know, it is becoming invisible when there is no connection (at all). for me I didn't see this issue when connection is up.
    if this is an issue, please report in feedback section.
  4. daster_x
    seems ok on my side. please report in feedback section of the issue persists
  5. daster_x
    about Bluetooth icon: it appears only when there is a connection (at least in my case ... beta 22/op5t)
  6. daster_x
    in recovery you can find this option
  7. yashydv21
    Eclair Jan 4, 2019
    yashydv21 , Jan 4, 2019 :
    where is VoLTE option in OpenBeta 22 for OnePlus 5T??
    i am using idea 4G as a provider
  8. smitbhagat
    Honeycomb Jan 4, 2019
    smitbhagat , Jan 4, 2019 :
    PlayStore suddenly shows Rh-01 error
    Tried clearing the cache,data and rebooted the phone, still no luck.
    Any suggestions?
  9. H1540968790956
    Froyo Jan 4, 2019
    H1540968790956 , Jan 4, 2019 :
    hi OnePlus team
    am having OnePlus 5f device and I installed open beta 22 which is latest build, am using Jio sim only one sim.
    now am facing signal fulcuations and sometimes in the sense alternate days sim1 slot will show sim is in inactive state and if I change the my Jio sim to sim2 slot then it will work fine for 2days after that without touching the phone it will automatically show sim2 inactive and again if I switch the sim to sim1 slot again it working fine. please OnePlus fix this issue as soon as possible because I have only one and am using single Jio sim only.
    note: I tried factory data reset also cleared phone memory also but am facing the same above issue.
    there is no probs in sim as it is a new sim.
  10. Mr_Cyrox
    KitKat Jan 4, 2019
    Mr_Cyrox , Jan 4, 2019 :
    Do you have 2 SIM cards in total in the device?
  11. H1540968790956
    Froyo Jan 4, 2019
    no only one sim that too Jio
  12. Mr_Cyrox
    KitKat Jan 4, 2019
  13. H1540968790956
    Froyo Jan 4, 2019
  14. vaibzbhardwaj
    Eclair Jan 4, 2019
  15. doom71
    Gingerbread Jan 4, 2019
    doom71 , Jan 4, 2019 :
    Mine is not!
  16. vaibzbhardwaj
    Eclair Jan 4, 2019
    vaibzbhardwaj , Jan 4, 2019 :
    The Frames are freezing a lot. its not smooth as the other builds
  17. Le_zOU
    Cupcake Jan 4, 2019
    Le_zOU , Jan 4, 2019 :
    (deleted, I misread :p)
    On a side note, even though I'm very happy with build 24, I'd like to go back to stable... is there any documented procedure for that ? (Beta -> stable)
    that in 1st post is not extremely clear to me:
    • Moving back to the Official OTA path from the Beta path will require a full install and clean flash (full wipe of all data and cache).
    Thank you
  18. H1540968790956
    Froyo Jan 4, 2019
    bro for op5 it's 24 for op5t it's 22 read the thread properly
  19. Abhig11
    Donut Jan 4, 2019
    Abhig11 , Jan 4, 2019 :
    many apps are crashing and in the parallel WhatsApp i am unable to download anything. and battery issue is there
  20. Jovericain
    Jovericain , Jan 4, 2019 :
    22 is the latest...for the 5t! I guess you didn't understand the thread title! it's for 22 and 24 depending on the device you use (5 or 5t).
    next time, be nice with people!
