172
OxygenOS Open Beta 24 for the OnePlus 5 and Open Beta 22 for OnePlus 5T
  1. Jairo_666
    Donut Jan 5, 2019
    Jairo_666 , Jan 5, 2019 :
    That's right. It's kind of laggy but also (almost in my case) when you just try to open a folder or the app's box. I thought it was only an issue in my 5t. Is not all the time, but is annoying every time it happens.
    X1513762687695 likes this.
  2. Jairo_666
    Donut Jan 5, 2019
    Exactly, except for the battery issue... I've been facing those problems after last open beta.
  3. Ajiteshmadai
    Eclair Jan 5, 2019
    Ajiteshmadai , Jan 5, 2019 :
    I am on beta even thought stable 9.0.1 has arrived. I wanted to know will the optimizations made as part of 9.0.1 will be backported in next beta or do i have to switch to stable?
  4. Q1527618185013
    Cupcake Jan 5, 2019
    Q1527618185013 , Jan 5, 2019 :
    If the task manager is kept open and the phone is locked and after few minutes if i unlock the phone, the task manager is still open in the front end. Ideally post locking and unlocking the phone it should go to home screen. Is this an issue? Is anyone else facing similar issue?
  5. Kapuya
    Cupcake Jan 5, 2019
    Kapuya , Jan 5, 2019 :
    Thank you
  6. Star007Knight
    Froyo Jan 5, 2019
    Star007Knight , Jan 5, 2019 :
    does anyone knows how to turn off the shutter sound on the camera on the OP5t? I did turn it off from the camera settings but it's still making the sound. I'm on Android pie latest beta.
  7. velu4you
    Cupcake Jan 5, 2019
  8. Pavansonline
    Cupcake Jan 5, 2019
    Pavansonline , Jan 5, 2019 :
    does anyone facing problem with Bluetooth car connectivity, the problem i am facing is contacts and recent calls are not shown on the car screen, i have accepted all necessary permissions while connecting the car Bluetooth
  9. JannePaa
    Cupcake Jan 5, 2019
    JannePaa , Jan 5, 2019 :
    Hi,
    If Open Beta 24 is installed to One Plus 5 phone. What is The next Ota version which will be installed to the phone?
    With Kind Regards
    @Janne
  10. Cervantes
    Moderator Moderator Jan 5, 2019
    Cervantes , Jan 5, 2019 :
    The first post it says: those who are in beta only receive beta updates
    The beta thread is a thread of questions and/or commentary
    Please, read the first post
    use the topic search instead of opening a new thread
    Thread merged
  11. Ansarirj
    Froyo Jan 5, 2019
    Ansarirj , Jan 5, 2019 :
    Ideally it will be open beta 25. I'm assuming u are on the open beta programme, if so then u will continue to receive incremental ota upgrades.
  12. Dr. Robert
    Gingerbread Jan 5, 2019
    Dr. Robert , Jan 5, 2019 :
    My 5T is running Beta 22 with no noticeable issues. However, whenever I reboot the phone, it hangs halfway through the process and just freezes. It then attempts to try again without any success. The only way to get the phone up & running is to boot from recovery. Then all seems fine until the next manual restart. Has anyone else encountered this issue? Suggestions welcome as to what is the best way to proceed.
    I should add this issue first appeared with Pie.
  13. DillzDilly
    DillzDilly , Jan 5, 2019 :
    I went straight to 9.0.1 but you have to flash with recovery mode. this will definitely wipe your data.
  14. DillzDilly
    open BETA 24 and stable 9.0.1 are exactly the same builds. what needs to be resolved are the minor stutters and the adoptive brightness. it seems to forget my preferences Everytime.
    RoyxD4 likes this.
  15. vaibhav.rustagi2015
    Froyo Jan 6, 2019
    vaibhav.rustagi2015 , Jan 6, 2019 :
    I m facing the issue with my usb type C earphones... nd it stops working sometimes in between call as well... please look into this OnePlus...
  16. Dextro_619
    Honeycomb Jan 6, 2019
  17. Q1527618185013
    Cupcake Jan 6, 2019
    Q1527618185013 , Jan 6, 2019 :
    Need improvement in camera for 5t and flash alert option
    the_reckoner likes this.
  18. X1513762687695
    Donut Jan 6, 2019
  19. sachinsankh
    Donut Jan 6, 2019
    sachinsankh , Jan 6, 2019 :
    I have downloaded 9.0.1 zip file,can i go directly from open beta 24-->9.0.1 update
  20. HalCapone
    HalCapone , Jan 6, 2019 :
    I said a week or so back.I think they maybe finished with trying to make the camera better.Has been so long since any real update to make it better has come out.
