172
OxygenOS Open Beta 24 for the OnePlus 5 and Open Beta 22 for OnePlus 5T
  1. Chiran_OP5
    Honeycomb Jan 8, 2019
    Chiran_OP5 , Jan 8, 2019 :
    yeah I can understand. I'm also confused about it. This is the screenshot from the conversation with Jeff.
  2. NavinThomsy
    Froyo Jan 8, 2019
    NavinThomsy , Jan 8, 2019 :
    If can save your self from a boot loop then I suggest you to install this and follow the steps:
    https://forum.xda-developers.com/apps/magisk/module-quickswitch-universal-quickstep-t3884797/
    AFAIK this app only brings pie recents menu (see screenshots in xda).
    Try on screen navigation after installing the module.
    (In my case I uninstalled a few days later. Only today when I switched to software keys , I noticed the pill gesture)
    TBH I don't think the app was meant to bring pie pill.
    But good luck trying!
    Chiran_OP5 likes this.
  3. Q1527618185013
    Cupcake Jan 8, 2019
    Q1527618185013 , Jan 8, 2019 :
    Can we have white color led notification
    the_reckoner likes this.
  4. Mr_Cyrox
    KitKat Jan 8, 2019
    Mr_Cyrox , Jan 8, 2019 :
    It's real:
    You can force gestures with ADB if you want a tutorial here it is:
    To enable/disable Pie gestures on OnePlus 5 and below:
    Code:
    Note! You must have ADB installed on your PC!
    And your device must be running Pie!
    1. Go to Settings > Buttons & Gestures > Buttons > Enable On-Screen navigation bar (This will get replaced with Pill navigation gestures after the process).
    2. Turn on USB Debugging from developer options and connect your phone to your pc.
    3. [PC] Open Windows Command Prompt or Windows PowerShell.
    4. Run this command:
    Code:
    adb shell settings put secure swipe_up_to_switch_apps_enabled 1
    To disable/restore:
    Code:
    adb shell settings put secure swipe_up_to_switch_apps_enabled 0
  5. V1546966178693
    Cupcake Jan 8, 2019
  6. CODEGEEK
    Gingerbread Jan 8, 2019
    CODEGEEK , Jan 8, 2019 :
    This is the beta thread Sherlock.
  7. ErynOP
    ErynOP , Jan 8, 2019 :
    Hey, what do you mean by "cleanly" ? With the ADB SIDELOAD thing ?
    If yes, do you have a tutorial that i can follow ? Thanks.
  8. Rambo15
    Froyo Jan 8, 2019
    Rambo15 , Jan 8, 2019 :
    A clean flashing is when you delete the cash and the devlink cash and data in the recovery or when you reset the phone to the factory settings.
    It's also possible via ADB because I have only a German description but you should also find it in English at xda
  9. ErynOP
    I see, i reset the phone to the factory settings for every major update so i suppose that's okay like that. :)
  10. Rambo15
    Froyo Jan 8, 2019
    [QUOTE = "ErynOP, Beitrag: 19788647, Mitglied: 1791619"] Ich verstehe, ich setze das Telefon für jedes größere Update auf die Werkseinstellungen zurück. Ich nehme an, das ist okay. :)[/ZITAT]
    ja das ist richtig und nach dem blinken von cash und devlink wieder booten
    Hoffnung ist lesbar, weil ich mit Übersetzern arbeite, weil mein Englisch sehr schlecht ist
  11. SP3NGL3R
    SP3NGL3R , Jan 8, 2019 :
    Anyone know what this icon is? It appeared pala week and hasn't gone away. (If image isn't visible, it looks like a glass screen protector)
  12. Tcat007
    Tcat007 , Jan 8, 2019 :
    Go to settings display status bar icons, and start turning each off and see when it disappears.
    SP3NGL3R likes this.
  13. SergiuXro
    Gingerbread Jan 9, 2019
    SergiuXro , Jan 9, 2019 :
    Auto rotate disabled (portrait mode only).
    Uncheck '''auto rotate screen" from Settings > Display > Status bar > Icon manager
  14. SP3NGL3R
    SP3NGL3R , Jan 9, 2019 :
    Twas indeed. I had it off so I guess it was a "portrait mode" icon. Thanks
    SergiuXro likes this.
  15. EitviisGr
    Cupcake Jan 9, 2019
    EitviisGr , Jan 9, 2019 :
    Tried to downgrade back to nougat, phone went to shit, google play services uninstalled once I downgraded the OS.. Such bullshit, that you cant downgrade from a beta system. Pie for OP5 is full of bugs, apps randomly crash, phone has to be force restarted to work. It's insane. OP do something about these issues, Im surely not the first person with these problems.
  16. dhruvweaver
    The Lab - OnePlus 7 Pro Reviewer Jan 9, 2019
    dhruvweaver , Jan 9, 2019 :
    It's a beta for a reason...
  17. mohangopi
    mohangopi , Jan 9, 2019 :
    then why you came into beta channel better to stick with stable
  18. Hariharan_k
    Cupcake Jan 9, 2019
    Hariharan_k , Jan 9, 2019 :
    Voice recorder app is missing for me in latest beta build!!! Is it the case for everyone??
  19. suryaraya
    Froyo Jan 9, 2019
    suryaraya , Jan 9, 2019 :
    guys can u help me how to change it the old layout it's really irritating to use this I have searched it but I didn't get what I was searching for just point me the direction
  20. NavinThomsy
    Froyo Jan 9, 2019
    NavinThomsy , Jan 9, 2019 :
    Thanks for this.
    I got the pill gesture without this. I don't know how though.
    But I will definitely follow your tutorial when the next beta comes as I don't know how to reproduce the same bug (I guess?).
    Mr_Cyrox likes this.
