171
OxygenOS Open Beta 24 for the OnePlus 5 and Open Beta 22 for OnePlus 5T
  1. Mr_Cyrox KitKat Jan 10, 2019
    Mr_Cyrox, Jan 10, 2019 :
    Beta builds are not late after there announcement thread is up (most of the time OnePlus 5 gets it first then OnePlus 5T but sometimes it happens the other way around)
    If you're on stable you have to flash this manually because you'll never get this through an OTA
    If you're referring to OxygenOS 9.0.1 use the correct thread as this is for Open Beta 24/22
  2. U1547051928554 Cupcake Jan 10, 2019
    U1547051928554, Jan 10, 2019 :
    I have OxygenOS version 5.1.7 and how can i get the latest version manually. Also i have heard that manual upgrade of OS leads to many software problems in the device. What do you recommend??
  3. Mr_Cyrox KitKat Jan 10, 2019
    There are 2 types of "updates":
    Open Beta and Stable
    Stable releases are mostly as the name suggests stable and comes by default out of the box...
    Latest Stable build is OxygenOS 9.0.1
    Open Beta is an experimental version of OxygenOS and it is not recieved automatically through OTAs if you're currently on a Stable release...
    This experimental build may have more bugs but you will get faster updates and more features faster then those who are using a Stable release...
    Latest Open Beta is:
    OnePlus 5 - Open Beta 24
    OnePlus 5T - Open Beta 22
    Your choice...
    You can download stable updates without waiting much by using the Oxygen Updater from the Google Play store
  4. U1547051928554 Cupcake Jan 10, 2019
    Mr_Cyrox
    Your choice...
    You can download stable updates without waiting much by using the Oxygen Updater from the Google Play store​
    Thank you for so much information brother.
    How can I get/download Stable OxygenOS update??
  5. U1547051928554 Cupcake Jan 10, 2019
    Thank you for reminding me about the word "sarcasm"
  6. Mr_Cyrox KitKat Jan 10, 2019
    As I said:
    U1547051928554 likes this.
  7. U1547051928554 Cupcake Jan 10, 2019
    Ohh sorry I didn't get to that.
    Thank you so much brother.
    Also one question : What about the rumor of erasing all the data of device after manual installation and some software problems??
  8. Mr_Cyrox KitKat Jan 10, 2019
    If you're not downgrading you don't need to worry
    Just follow the instructions and you should be good to go
    But backups are always recommended
  9. U1547051928554 Cupcake Jan 10, 2019
    Mr_Cyrox
    Just follow the instructions and you should be good to go​
    Thanks brother. I ll follow the instructions and on any problem will contact you.
    Brother what is this screen. I always have to slide this screen after unlocking phone. Do u have any idea???
  10. HalCapone Honeycomb Jan 10, 2019
    HalCapone, Jan 10, 2019 :
    Could someone help me out. I use an app called CheckMyBus in the uk.Since this update it does not seem to look up times for me.Could someone please download it and see if it's working for them.The dev told me the app has been updated to work with pie but still no luck.
  11. Klimo Froyo Jan 10, 2019
    Klimo, Jan 10, 2019 :
    I can install the app, but I can not select anything Screenshot_20190110-120653.jpg
  12. HalCapone Honeycomb Jan 10, 2019
  13. Rotten Egg Honeycomb Jan 10, 2019
    Rotten Egg, Jan 10, 2019 :
    Now OP is busy in releasing pie for 3/T. So beta update for 5/T might be delayed......I guess...
    the_reckoner and Chiran_OP5 like this.
  14. crazyidiotviggu Cupcake Jan 10, 2019
  15. Klimo Froyo Jan 10, 2019
    of course
    crazyidiotviggu likes this.
  16. G_Patel_Bhargav_GlHw Gingerbread Jan 10, 2019
    Siddj38 likes this.
  17. crazyidiotviggu Cupcake Jan 10, 2019
  18. simoniub Gingerbread Jan 10, 2019
  19. aryan_kh1 Eclair Jan 10, 2019
    aryan_kh1, Jan 10, 2019 :
    The updates for op 6/6t weren't delayed when we were waiting [e]1f614[/e]
  20. G_Mateo_DxQd Honeycomb Jan 10, 2019
    G_Mateo_DxQd, Jan 10, 2019 :
    Is the beta program for OnePlus 5 and 5T still active?? I've noticed that they have been unpinned and haven't found beta 25-23 online.
    And, side question, anyone knows if 9.0.2 has caught up with the betas?
