109
OxygenOS Open Beta 24 for the OnePlus 6 and Open Beta 16 for OnePlus 6T
  1. ironass
    Lollipop Aug 8, 2019
    ironass , Aug 8, 2019 :
    Did this only start after yesterday's Open Beta update?
    Have you tried the usual steps of wiping the cache of the affected apps and have you done a Factory Reset to see if that solves your problem?
  2. Lu00765
    Froyo Aug 8, 2019
    Lu00765 , Aug 8, 2019 :
    it started after yesterday's update, I'm about to clean cache but I can't factory reset my phone right now even if I wanted too, too much trouble settings things up again[e]1f602[/e]
  3. jvangat17
    Donut Aug 8, 2019
    jvangat17 , Aug 8, 2019 :
    Spotify App being killed suddenly when pause on the notification bar.
    Restarted the phone > same issue
    clear spotify app cache > worked for a few minutes but after a few minutes issue came back.
    add to not optimised app > same issue
    clear spotify cache again> same issue
    clear phone cache > same issue
    Note: recent app management is set to normal clear
    and I did not kill it on recent apps.
    it is working when you pause it on notification bar while you are inside the spotify app.
    issue arises when you pause it when you are on the home page or other apps.
    A3aan79 and Lu00765 like this.
  4. Lu00765
    Froyo Aug 9, 2019
    Lu00765 , Aug 9, 2019 :
    same problem here too
    A3aan79 likes this.
  5. Ippolito1971
    Honeycomb Aug 9, 2019
  6. F_Madhoo_Kanth_EtXF
    Cupcake Aug 9, 2019
    F_Madhoo_Kanth_EtXF , Aug 9, 2019 :
    I am facing an issue with my network after making a new software update on 8th August. My phone is unable to receive the network.
  7. ironass
    Lollipop Aug 9, 2019
    ironass , Aug 9, 2019 :
    From your other post, here, you are on Airtel, India.
    According to Downdetector, Airtel, India, has been experiencing multiple network outages, nationwide, in the last 24 hours. To quote from their site...
    "Recent reports mostly originate from: Bengaluru, New Delhi, Mumbai, Pune, Chennai, Kolkata, Delhi,Jaipur, Hyderabad, and Ahmedabad."
    See, map...
    https://downdetector.in/status/airtel/map/
    See, also...
    drl431 likes this.
  8. F_Madhoo_Kanth_EtXF
    Cupcake Aug 9, 2019
    May be but the thing is before the update phone was able to receive full network but after the update it is even unable receive a single point of network.
  9. N1531281691681
    Cupcake Aug 9, 2019
  10. Neelakanta Rao
    Eclair Aug 9, 2019
  11. Artemus.
    Nougat Aug 9, 2019
    Artemus. , Aug 9, 2019 :
    You won't get this one unless you're already on the beta path. And don't ask me how 'cause it's clearly written on the first page.
    drl431 likes this.
  12. shaner243
    Cupcake Aug 9, 2019
    shaner243 , Aug 9, 2019 :
    I filled out the feedback form. I was having some issues with the screen not registering my taps. But, it looks fine now
  13. Q1550980810560
    Donut Aug 9, 2019
  14. Artemus.
    Nougat Aug 9, 2019
    First, don't yell. Second, this is the beta. You won't be getting this build unless you already are on the beta channel... and don't ask me how to do so.
  15. KeLeM
    Cupcake Aug 9, 2019
    santiagoopintos and drl431 like this.
  16. prashanth ch04
  17. G_mj_ashok_PXeI
    Cupcake Aug 9, 2019
    G_mj_ashok_PXeI , Aug 9, 2019 :
    sir fortnite game in one plus 6t is stucking while playing please give an update and please made phones best not worst like 6t.
  18. Chay@krishna
    Eclair Aug 9, 2019
  19. Hurtxxx
    Cupcake Aug 9, 2019
  20. R1565327305229
    Cupcake Aug 9, 2019
