109
OxygenOS Open Beta 24 for the OnePlus 6 and Open Beta 16 for OnePlus 6T
  1. ade0410
    Honeycomb Aug 17, 2019
    ade0410 , Aug 17, 2019 :
    What version OS are you running?
    When did this start happening?
    What have done to try and fix the problem?
    Without any more information what are OP supposed to fix?
    And they don't read these forums so report it through the proper way.
  2. Xcutioner
    Gingerbread Aug 17, 2019
    Xcutioner , Aug 17, 2019 :
    Why am I opening the forums every few hours? hoping for a miracle that they'd drop OOS Q beta? The sleep less nights have begun. Still surprised Google hasn't revealed the name yet. They revealed Pie earlier last year.
  3. drl431
    KitKat Aug 17, 2019
    drl431 , Aug 17, 2019 :
    Based on last year with pie, you'll need to wait at least a few months for open beta Q on the OP6/6t.
    Kytharsis, Xcutioner and ironass like this.
  4. Xcutioner
    Yea, but 6/6T software updates have been better this year than it was for 5/5T last year. also apparently H²OS got it's last Pie beta for 6/6T... I am hoping that means next OB will be Q...
    drl431 likes this.
  5. drl431
    KitKat Aug 17, 2019
    Ok, but the OP7 series would still get open beta Q first, and that would be after Android Q final is released.
    Kytharsis and Xcutioner like this.
  6. Xcutioner
    Yep...
    drl431 likes this.
  7. N1564443997798
    Cupcake Aug 17, 2019
    Xcutioner likes this.
  8. Xcutioner
    I didn't notice a difference... Well I mostly have charger nearby so I wouldn't notice even if it had gotten worse.
  9. G_Ankit_Sharma_RVBD
    Eclair Aug 17, 2019
    G_Ankit_Sharma_RVBD , Aug 17, 2019 :
    I'm trying to move to stable update which is Oxygen OS 9.0.16. But Its keeps showing error that my phone currently have higher open beta version. But 9.0.16 stable is released after the latest Open beta of 6T.
  10. ironass
    KitKat Aug 17, 2019
    ironass , Aug 17, 2019 :
    The reason for that is explained in post #6. Open Beta is newer than the stable OxygenOS. Simple! :D
    See post #493 of this thread.
  11. Xcutioner
    Pretty sure you have to use the rollback package in the post to go back to Stable and will do a full wipe. from Stable to Beta is easy but going back is not.
    Kytharsis likes this.
  12. G_Ankit_Sharma_RVBD
    Eclair Aug 17, 2019
    Thanks. I'm gonna use the full wipe method.
  13. Xcutioner
    curious, why are you going back to stable? worried first Q betas will have a lot of bugs?
  14. G_Ankit_Sharma_RVBD
    Eclair Aug 17, 2019
    Some Basic Features are very buggy. Like Bluetooth Lag and Spotify & Youtube are also crashing. Phone Heating issue and Battery Drainage. I have another OP6T phone in my family and That one is running stable OS and All the above mentioned problems are not present there. That's why moving to stable
    reycosare, Kytharsis and Xcutioner like this.
  15. Xcutioner
    YouTube and Spotify crashing is probably caused by something else... I don't have that issue, I don't notice the others as well. Well going back to stable will probably fix those since full wipe.
    ade0410 and Kytharsis like this.
  16. Elinth
  17. rohitsharma_j22
    Gingerbread Aug 18, 2019
    rohitsharma_j22 , Aug 18, 2019 :
    Battery is draining on very high pace. I found culprit is google play service. it is taking more than 50% battery daily. i hv cleaned its cache but no benefit.
    Those who are getting 7-8 hr SOT, can you please suggest how you guys are getting such battery life. Mine is OP 6.
  18. B_Wrath
    Marshmallow Aug 18, 2019
    B_Wrath , Aug 18, 2019 :
    Clear the data of play services and reboot your phone.
    Kytharsis and Maverick2.0 like this.
  19. Xcutioner
  20. MMuralidhar
    MMuralidhar , Aug 18, 2019 :
    form today morning I am able to see below option in android messages, after enabling the same it says your device don't support
    I am from India , using Airtel and Jio Sims. any solution
