109
OxygenOS Open Beta 24 for the OnePlus 6 and Open Beta 16 for OnePlus 6T
  1. Aziz_Amin_Oneplus
    Jelly Bean Aug 22, 2019
    Aziz_Amin_Oneplus , Aug 22, 2019 :
    Backup your data anywhere safe, factory reset your phone, download the stable 9.0.8 version in your mobile storage, install the update from recovery mode and you are good to go.
  2. Niklasg85
    Backstage Star Award 2021 Aug 22, 2019
    Niklasg85 , Aug 22, 2019 :
    please Read THE first post!
    Artemus likes this.
  3. F_Elangovan_Kaliyamoorth
    Cupcake Aug 22, 2019
    F_Elangovan_Kaliyamoorth , Aug 22, 2019 :
    how do i update by recovery mode
  4. ironass
    Lollipop Aug 22, 2019
    ironass , Aug 22, 2019 :
    Well... that won't work I am afraid. Open Beta 24 is a newer build than OxygenOS 9.0.8.
    See post #6 of this thread for other methods of reverting to stock, stable, OxygenOS.
    B_Wrath, Artemus and Maverick2.0 like this.
  5. Aziz_Amin_Oneplus
    I have done it many times over new open beta builds, no problem with me so it is fine to carry on.
  6. Aziz_Amin_Oneplus
    Hold and Press power and volume down button till you feel any vibration, once its done go to English, install from storage then select the file and install the update.
  7. ironass
    You cannot downgrade to an earlier release by simply flashing stock OxygenOS in recovery. You can only upgrade. All Open Beta testers know this. :D
    B_Wrath and Maverick2.0 like this.
  8. Aziz_Amin_Oneplus
    I am also a open beta tester, I know everything, if any problem occurs then reset system setting it will be good to go, test it yourself you will know everything lol.
  9. Maverick2.0
    KitKat Aug 22, 2019
    Maverick2.0 , Aug 22, 2019 :
    I seem to have run into a bit of a problem, but not sure if it's due to OB 24.
    I got myself the Honor Band 4 around the same time as OB 24 dropped. Now, I see there's noticeable battery drain. Could it be because the band is connected via Bluetooth or is it something with OB 24? ( I am unsure because I read several comments where other testers have said battery life is excellent on this build).
    My usage is moderate with mobile data, GPS & now Bluetooth always on.
    Any help will be appreciated.
  10. wolf4477
    Froyo Aug 22, 2019
  11. Xcvirajcx
    Eclair Aug 22, 2019
    Xcvirajcx , Aug 22, 2019 :
    Audio In Slow Mo Rec could be a Thing! I am a Video Creator and Slow mo Comes in handy but when ever I need a Slow Mo ramp in same Cut its tough because the audio isn't recorded.
  12. ngydat
    ngydat , Aug 22, 2019 :
    A video creator doesn't just use his phone to create content
  13. Xcvirajcx
    Eclair Aug 22, 2019
    A Creator is a Creator doesn't matter what Gear the person uses also You cant carry all the Equipments Everywhere and set everything up everytime. Also next time please Keep your Nose to your self it sometimes does wander into other's Business thanks.
  14. ngydat
    Read this article https://www.diyphotography.net/record-slow-motion-sound-tomato-exploding-60000fps/
    Even the video camera mentioned in the article doesn't capture sound in slow-motion (whereas this a video camera for professional)
  15. GauravaRai
    Honeycomb Aug 22, 2019
  16. Darrenc81
    Gingerbread Aug 22, 2019
    Darrenc81 , Aug 22, 2019 :
    sorry but that's actually correct. OnePlus DP3 is based on Google's beta 5.
    OnePlus DP4 was based on Google beta 6 but jumped the gun and released before Google (only for 7 series)
    Oneplus probably won't give further previews on the 6 series, or any updates in fact until the Q open beta later in the year (well hopefully we get stable security patches for September and October at least...)
    open beta programme is on hold as was announced on the Chinese Hydrogen OS boards (typically hydrogen OS releases first then we get OOS based on it)
    TheAyushJain likes this.
  17. muugee
    muugee , Aug 22, 2019 :
    So no update for open beta 17 for now? That's quite disappointing. Or it's just for the Android Q DP?
  18. TheAyushJain
    TheAyushJain , Aug 22, 2019 :
    That is upto Oneplus to decide !
  19. Darrenc81
    correct, most likely scenario
  20. mak0864
    Aziz_Amin_Oneplus likes this.
