597
OxygenOS Open Beta 25 for the OnePlus 3 and 16 for the OnePlus 3T (Android O)
Thread Status:
Not open for further replies.
  1. pablofg1978
    Head Moderator Head Moderator Oct 16, 2017
    abhiiceman likes this.
  2. the_crazy_shady
    Gingerbread Oct 16, 2017
    the_crazy_shady , Oct 16, 2017 :
    The notifications are not show properly, only half of it is visible, especially on UC browser.
    also there is massive battery drainage.
    Ankitbhat12345 likes this.
  3. pablofg1978
    pablofg1978 , Oct 16, 2017 :
    Thread merged
    Read the first post
  4. zuzar
  5. G_Alexander_I_vZiE
    Froyo Oct 16, 2017
  6. 4sheesh
    Honeycomb Oct 16, 2017
    4sheesh , Oct 16, 2017 :
    perfect black qs bg and notification panel !!! :D ( partial OMS support )
  7. saswaraj
    Eclair Oct 16, 2017
    saswaraj , Oct 16, 2017 :
    I lost the connectivity of one sim major bug which made me to go back to beta 24
  8. mirza1981
    Cupcake Oct 16, 2017
    mirza1981 , Oct 16, 2017 :
    I already check but same
  9. saswaraj
    Eclair Oct 16, 2017
  10. Fast_and_Curious
    Jelly Bean Oct 16, 2017
    Fast_and_Curious , Oct 16, 2017 :
    Apt-X is still available but renamed as "optional codecs". But even if we enable it, it reverts back to system default again. Hope this will be solved in the final build.
  11. Nirvanes
    Eclair Oct 16, 2017
    djikata likes this.
  12. kbszh123
    kbszh123 , Oct 16, 2017 :
    they already told! have some bug
  13. G_BROKEN_Liars_wxuK
    Donut Oct 16, 2017
  14. Fast_and_Curious
    Yes RCS service have been draining a lot of battery. It stopped when I turned off Volte from Sim Settings since it was not available for my network anyways. Since then RCS drain has minimized fully.
    Nirvanes and G_Joshua_Snow_spGi like this.
  15. fdroko
    fdroko , Oct 16, 2017 :
    wipe data
  16. G_George_Fratian_UvHb
    Donut Oct 16, 2017
    G_George_Fratian_UvHb , Oct 16, 2017 :
    this update causes the internet to stop functioning after 10-15 min of a reboot, literally annoying asf. Plz fix soon, I'm going to revert back to previous build
    MrSolomon2611 likes this.
  17. G_Joshua_Snow_spGi
    Donut Oct 16, 2017
    G_Joshua_Snow_spGi , Oct 16, 2017 :
    idk guys everything is working fine for me. no Bluetooth issues. all of my apps work so far and no network issues also and I'm using 2 Sims.
  18. andh1ka
    Froyo Oct 16, 2017
    andh1ka , Oct 16, 2017 :
    any body got a 'mobile data plan run out' bug ?
    i got it everytime using "switch data" quick setting on sim 2
  19. Naren25
    Naren25 , Oct 16, 2017 :
    How can I solve this.?
  20. ashwin.243
    ashwin.243 , Oct 16, 2017 :
    Hi, it is always recommended to wipe the cache partition just after you flash the update to avoid any issues from the previous cache.
    Instead of updating from the OTA, I downloaded the full ZIP (1.4GB) from the downloads portal, went to the recovery, flashed the zip and then wiped the cache.
    For me there are no night mode or app crashing issues or call screen flickering. I do agree that the battery life is not as good as the previous build but no other issues here. ROM is fully functional.
    I would suggest you to download the full ZIP, flash it from recovery and then wipe the cache partition and then see how it works.
    bizius63 likes this.
