597
OxygenOS Open Beta 25 for the OnePlus 3 and 16 for the OnePlus 3T (Android O)
Thread Status:
Not open for further replies.
  1. Kéno40
    Jelly Bean Oct 17, 2017
    Kéno40 , Oct 17, 2017 :
    After installing TWRP, just reboot the TWRP once. Then it should stick.
    sammerasker likes this.
  2. VaibhavBhargava
    Lollipop Oct 17, 2017
  3. myshyak
    Cupcake Oct 17, 2017
    myshyak , Oct 17, 2017 :
    In Dark theme gmail becomes unusable - you don't see text of messages.
    Waze do not start- gives error
    Ankitbhat12345 likes this.
  4. VaibhavBhargava
    VaibhavBhargava , Oct 17, 2017 :
    #1 feedback link is given
    And does the Android Oreo brings these features as part of the OS ?
  5. r4wky
    Eclair Oct 17, 2017
    r4wky , Oct 17, 2017 :
    When we clear the notifcation in the status bar, the notification dot also disappears. Is there any way to keep the notification dot on if the notifications are cleared.
  6. Ujjwal85
    Gingerbread Oct 17, 2017
  7. G_xisoshheng_cao_MFIq
    G_xisoshheng_cao_MFIq , Oct 17, 2017 :
    Hello,
    Can you set up a switch to switch the dual signal of China Telecom into a single signal?
    Because the status bar on the double signal is ugly.
  8. mharis
    Ice Cream Sandwich Oct 17, 2017
    mharis , Oct 17, 2017 :
    Picture in Picture works.
    I have tested it with VLC and Chrome. Couldn't test YouTube Red because it is not available in my country.
  9. aquilla
    aquilla , Oct 17, 2017 :
    Microphone of headset is not working since update. Someone else has the same problem?
  10. rahulvishwakarma
  11. abdulkareem.alnas
    Eclair Oct 17, 2017
  12. Petjitsu
    KitKat Oct 17, 2017
    Petjitsu , Oct 17, 2017 :
    you have already used the feedback option
    VaibhavBhargava and Sun90 like this.
  13. Petjitsu
    KitKat Oct 17, 2017
    then you have the option of returning to a stable version
    Sun90 likes this.
  14. Paweł_Babilas
    Paweł_Babilas , Oct 17, 2017 :
    Only problems after update :(, adobe reader not working, battery drain extreamly, no one day work without any stress and lags. Waiting for fix.
  15. asasione
    asasione , Oct 17, 2017 :
    For YouTube you can install this modded version
    https://forum.xda-developers.com/android/apps-games/app-iytbp-injected-youtube-background-t3560900
    Make sure you install microG so you can sign in but it works perfect for PiP, don't turn off screen while playing PiP
    Sun90 likes this.
  16. abdulkareem.alnas
    Eclair Oct 17, 2017
    abdulkareem.alnas , Oct 17, 2017 :
    waiting for update to fix these issues
  17. aakarpost
  18. Petjitsu
    KitKat Oct 17, 2017
    yes, it's one of the options
    Sun90 likes this.
  19. Petjitsu
    KitKat Oct 17, 2017
    VaibhavBhargava, Sun90 and Auristic like this.
  20. Auristic
    Auristic , Oct 17, 2017 :
    Then please don't post here!
    Sun90 likes this.
