597
OxygenOS Open Beta 25 for the OnePlus 3 and 16 for the OnePlus 3T (Android O)
Thread Status:
Not open for further replies.
  1. G_Darren_Lindley_WBkl
    Cupcake Oct 17, 2017
  2. G_Tamilselvan_R_sYzU
    Honeycomb Oct 17, 2017
    G_Tamilselvan_R_sYzU , Oct 17, 2017 :
    VLC doesnt works for me, tried using the latest VLC beta version also.. am i missing something ?
    Note: picture-in-picture option enabled in VC settings
    EDIT:
    Ok, found it, need to enable pic-in-pic option in preferences-video-action on application switching... works now
    mharis likes this.
  3. abdulkareem.alnas
    Eclair Oct 17, 2017
    abdulkareem.alnas , Oct 17, 2017 :
    Do any one did a factory reset after the upgrade to Android O 8.0??
    I want to have a feedback if the issues solved after doing clean reset.
    please see the secreen shot
  4. Anandrv
    Froyo Oct 17, 2017
  5. adrien079
    Eclair Oct 17, 2017
    adrien079 , Oct 17, 2017 :
    Well I really hope they will put back aptx support cause the difference in quality is massive.
    sammerasker likes this.
  6. CaptArcadian
    Donut Oct 17, 2017
    CaptArcadian , Oct 17, 2017 :
    Getting a backup of 3-4 hours and you advise it for daily use.
    Screen flickers so bad while receiving calls or in lock screen and you advise it for daily use.
  7. L1508234967383
    L1508234967383 , Oct 17, 2017 :
    I updated to Oreo beta few days ago and sometimes the mobile data doesn't working until I reboot the phone
    someone else have this problem ?
    Zlatakus, donthu and Q1508236650651 like this.
  8. thegrandvezir
    Froyo Oct 17, 2017
    thegrandvezir , Oct 17, 2017 :
    get your head out your *** man
    VaibhavBhargava and sammerasker like this.
  9. junaidr96
    Eclair Oct 17, 2017
    junaidr96 , Oct 17, 2017 :
    Screen color changes, more like black and white, for a while when i try to open any app...
  10. liam_davenport
    Gingerbread Oct 17, 2017
    liam_davenport , Oct 17, 2017 :
    SD801 Chipset is EOL and this isn't the place to ask
  11. Ankitbhat12345
    Jelly Bean Oct 17, 2017
    Ankitbhat12345 , Oct 17, 2017 :
    This are not a major bugs. If u wanna feel what are the major bugs go for any custom alpha stage rom. Now for me call flicker is gone after reset. Battery backup 4.5 hours sot.
    Sun90 likes this.
  12. mharis
    Ice Cream Sandwich Oct 17, 2017
    mharis , Oct 17, 2017 :
    Glad to hear!
  13. GopalB.
    Nougat Oct 17, 2017
    GopalB. , Oct 17, 2017 :
    That is a problem with most of the phones...
    What happens is when you turn off the mobile data, sometimes the carrier (Service provider) breaks your dedicated data path to reduce their bandwidth...
    And when you switch it on, it won't work...
    Don't switch off your phone... Just a simple airplane mode on off will help...
    As it force your phone to reconnect with the service provider and it will surely help...
    This issue occurs either at places where signal is weak... Or there are too many users..
    Hope this helps...
    Sorry for being too technical, I tried my best to be as clear as possible...
    donthu likes this.
  14. sankalp_999
    Donut Oct 17, 2017
    sankalp_999 , Oct 17, 2017 :
    Facing the same issue. Suddenly mobile data stops working and then even WiFi doesn't work. I have to reboot the phone to get it working again. Facing a bunch of other issues as well, quite a buggy build but it will get better with the upcoming builds. Can't expect everything to be working properly otherwise it won't be a beta
  15. sankalp_999
    Donut Oct 17, 2017
    I am facing the same issue, I've tried using the airplane mode making the same assumptions hasn't helped me :/
    Q1508236650651 likes this.
  16. asasione
    asasione , Oct 17, 2017 :
    I hope you realize @Ankitbhat12345 experience isn't the same for everyone else. I get 4 hrs SOT when battery is at 50% on this beta Oreo build. His post is mostly right though it's daily driver ready despite some bugs which are to be expected
  17. GopalB.
    Nougat Oct 17, 2017
    And by reduce their bandwidth, I mean reduce their overall data usage...
    Because they have limited paths...
    It's like they have limited number of cars, and if someone is not using the car assigned to them from a long time, they'll give it to someone in need, and when you come back to use that car, they don't have any left...
  18. GopalB.
    Nougat Oct 17, 2017
    If its happening in between, then that's an issue...
    Is this happening while travelling?
    donthu likes this.
  19. niyu26
    niyu26 , Oct 17, 2017 :
    I am getting notification DOT for all the apps like Tweeter, true caller, and others however not getting for whatsapp. Even if someone send me direct message or message in group, I am not getting notification DOT in whatsapp.
    Any suggestion on the settings to be checked...
  20. donthu
    Donut Oct 17, 2017
    donthu , Oct 17, 2017 :
