597
OxygenOS Open Beta 25 for the OnePlus 3 and 16 for the OnePlus 3T (Android O)
Thread Status:
Not open for further replies.
  1. gonath
    Froyo Oct 20, 2017
    gonath , Oct 20, 2017 :
    I am from India. Signal is not coming for Vodafone and Idea networks without data is on after the Oreo update in op3. where as BSNL sim signal is working fine.
    my secondary sim is Jio and it's working fine with BSNL sim. anyone facing this issue.
  2. G_ankur_soni_rALK
    Cupcake Oct 20, 2017
    roryrudy likes this.
  3. G_ankur_soni_rALK
  4. G_ankur_soni_rALK
  5. dhammuu
    Donut Oct 20, 2017
    dhammuu , Oct 20, 2017 :
    Hi, I recently updated my oneplus 3 to Oreo through open beta. here is the most annoying bugs i noticed after update.
    1. cell standby is consuming lots of battery
    2. picture in picture is not working properly
    3. if i kept my phone for sometime with data on,after sometime the internet is not working. then i have to restart my device to make it work. this is big annoying issue, please fix it.
  6. raja.d
    Ice Cream Sandwich Oct 20, 2017
    raja.d , Oct 20, 2017 :
    first backup your all data then go recovery and wipe data and cache.it will solve your problem..
  7. Yuvraj2099
    Gingerbread Oct 20, 2017
    Yuvraj2099 , Oct 20, 2017 :
    I'm using Vodafone, and it's working flawlessly for me. Might wanna check your device or sim
  8. mharis
    mharis , Oct 20, 2017 :
    I believe fixes can be delivered only via updates, and there has been no update since beta 25/16.
    We are all waiting, aren't we.
    Predict23 likes this.
  9. sashank1
    sashank1 , Oct 20, 2017 :
    Picture in picture is working absolutely fine. Have faced the other 2 issues as well.
  10. mharis
    It works, but they have implemented a feature in the latest release which uses the various sensors on the phone to determine the IQ of the user, so it uses that information and works only for those who have brains good enough to use a smartphone the way it is meant to.
  11. gonath
    Froyo Oct 20, 2017
    Can you please switch off the data for Vodafone and switch on the data for other sim. then please let me know signals are receiving or not in Vodafone sim
  12. Yuvraj2099
    Sorry bro, but I'm only using one sim, and that's Vodafone
  13. gonath
    Froyo Oct 20, 2017
    I think that's why you are getting signals. if I switch data to Vodafone, signals are coming. without data on, there won't be a signal for me. this is my problem.
  14. Kasios79
    Kasios79 , Oct 20, 2017 :
    People. Do you know anything about the patch to solve the super serious problem of mobile data internet ?.:confused:
  15. gstavrev
    Froyo Oct 20, 2017
    gstavrev , Oct 20, 2017 :
    Just wanted to share some findings on the Mobile standby drain. I think its some sort if visual bug. Last night when I went to bed i had 35% battery, and Mobile standby was in third place on the battery graph with 11% usage , after Screen and Android system. This morning after 7,5hrs of sleep the battery was still at 35%, but Mobile standby was at the top of the graph with 17% usage. This does not make any sense, how can the Mobile standby be increased so much if the phone didn't consume even 1% battery over night?
  16. Yuvraj2099
    So what you're saying is, your Vodafone Sim won't work, unless you use mobile data from that Sim ?
  17. Yuvraj2099
    I think the reason for the device having a standby drain is that the device isn't going to sleep properly. If you see in the attached screenshot, the screen is off for few hours in the start, but the device hasn't gone in sleep. What do you guys think ?
  18. G_keyzan_keyzan_JpIq
    G_keyzan_keyzan_JpIq , Oct 20, 2017 :
    do you have a brain? because its look like you didnt.
  19. jerry math
    Eclair Oct 20, 2017
    jerry math , Oct 20, 2017 :
    That i know man, they need to resolve problems man
  20. gonath
    Froyo Oct 20, 2017
    Yes. I tried with Idea sim also but no use.
