597
OxygenOS Open Beta 25 for the OnePlus 3 and 16 for the OnePlus 3T (Android O)
Thread Status:
Not open for further replies.
  1. Dresa91
    User of the Year 2016; Most Active User 2020 Oct 24, 2017
    Dresa91 , Oct 24, 2017 :
    When it is ready.
    Noone knows, there is no ETA.
    Wait and be patient.
    It won't help if we all ask every single day!
    VaibhavBhargava, Sun90 and Fufu2 like this.
  2. marius.herea
    Eclair Oct 24, 2017
    marius.herea , Oct 24, 2017 :
    All unreal engine games have horendous framerate.
  3. gustavhalling
    Eclair Oct 24, 2017
  4. G_James_Taaffe_MYxD
    Ice Cream Sandwich Oct 24, 2017
  5. tejakgp
    Honeycomb Oct 24, 2017
    tejakgp , Oct 24, 2017 :
    @any moderator if possible next time please reserve first two posts for issues and workarounds so that people can refer to instead of scouring the thread for solutions.
    @Others facing data issue whenever I have data connection failure I observed that a notification pops up saying some X application is running in the background. Can it be related to this by any chance?.
  6. G_Hiren_Trivedi_JfFZ
    Gingerbread Oct 24, 2017
    Ankitbhat12345 likes this.
  7. MariusZilinskas
    Cupcake Oct 24, 2017
    MariusZilinskas , Oct 24, 2017 :
    Is it possible to somehow change color of buttons in quick access menu?
    I have selected default theme and I would like it to look as stock android. In stock Android O buttons should be white, not blue. Any ideas?
  8. AcmE85
    AcmE85 , Oct 24, 2017 :
    You're sure it's not possibly caused by Substratum?
    Try if removing the theme fixes the issue.
    The only way is to use Substratum, which is either free when your device is rooted,
    or costs a little as you will need Andromeda additionally for unrooted devices.
    https://play.google.com/store/apps/details?id=projekt.substratum&hl=en&gl=us
    https://play.google.com/store/apps/details?id=projekt.andromeda&hl=en&gl=us
    Edit:
    you can also try this tool: https://www.xda-developers.com/customize-oxygenos-unlock-hidden-features-joneplus-tools/
    But be warned, I've read of issues on Reddit.
  9. Fufu2
    Jelly Bean Oct 24, 2017
    Fufu2 , Oct 24, 2017 :
    Poeple this is a beta build!
    We must help to find the issues.
    This is the reason of a community.
    Update comes when is ready of want you cry again?
    Enjoy this great Rom
    Greating Fufu
    K_Praneeth_Reddy and Sun90 like this.
  10. James Matthew Wells
    James Matthew Wells , Oct 24, 2017 :
    I'll be honest, the screen flicker issue when you get a call is more annoying to me than the network issue. The network issue only crops up occasionally at work, but never at home. I cannot answer calls in time more often than not...
    But for a first beta of a new version of Android, OnePlus did a really good job. I am sure it will be sorted out soon.
    Fufu2 likes this.
  11. Auristic
    Lollipop Oct 24, 2017
    Auristic , Oct 24, 2017 :
    Search for "Andromeda" in this thread (paid Add-on).
    VaibhavBhargava and Sun90 like this.
  12. Hemanth KUMAR W
    Eclair Oct 24, 2017
    Hemanth KUMAR W , Oct 24, 2017 :
    Has anyone tried sending files using share it to IPhone or any other device.. looks like there's problem...
    Could someone reply back if its working or not...
    Thanks.
  13. CoolBuddy44
    Donut Oct 24, 2017
  14. Sun90
    Starting Point Expert Community Expert Oct 24, 2017
    Sun90 , Oct 24, 2017 :
    Lot of application are yet to be optimized with Oreo.
    Do pls go through the first post of this thread.
    ghostofcain and VaibhavBhargava like this.
  15. 4sheesh
    4sheesh , Oct 24, 2017 :
    its seeming that u r using custom overlay via substratum .... switch back to default will fix ur problem
  16. G_Hiren_Trivedi_JfFZ
    G_Hiren_Trivedi_JfFZ , Oct 24, 2017 :
    thanks i will try and update you later
  17. bigalcy
  18. VaibhavBhargava
    VaibhavBhargava , Oct 24, 2017 :
    The first one is reserved for the guy who creates this thread.
    The second one pretty much covered the bugs(thanks to @Ankitbhat12345 ), sadly no known fixes exist at the moment.
  19. G_Raj_Onu_CwaL
  20. mharis
    mharis , Oct 24, 2017 :
    Is there any way to access battery details from Navigation bar/ pull down? I am only able to access it by long pressing the "Battery Saving" tile on quicksettings.
    On the older versions you could tap on the battery percentage on status bar to do so.
