597
OxygenOS Open Beta 25 for the OnePlus 3 and 16 for the OnePlus 3T (Android O)
Thread Status:
Not open for further replies.
  1. daninantro
    Ice Cream Sandwich Oct 15, 2017
    daninantro , Oct 15, 2017 :
    How many charge cycles did you go through to determine that correct SOT you mentioned? As the build was just posted yesterday.
    Also why check SOT? Check for battery drain when screen on instead of SOT. :)
  2. Sulimanalobody
    Froyo Oct 15, 2017
    Sulimanalobody , Oct 15, 2017 :
    I have some observations that I want you to take it into consideration
    1st : Readd (fast changing Wi-Fi / Bluetooth/els source) in Quick Sittings
    2nd : Readd (power notification control)
    3rd : Picture in picture , does not work
    4th : Force 4G network mode
    5th : Revert application icons to their original form
    6th : Add ( changing the font from external sources )
    7th : Redesign boot animation
    8th : Make tiles size more adjustable
    9th : Lock the physical buttons with alert slider
    10th : Bug in Words dictionary
    11th : Shelf works without using OnePlus lancher as default
    12th : Substratum works without root request
    13th : Readd diagram (battery usage, last full charge)
    **I don't Speak English very well Please don't miss understand me
    Please reply if you don't agree with me
  3. Ankitbhat12345
    Jelly Bean Oct 15, 2017
    Ankitbhat12345 , Oct 15, 2017 :
    Picture and picture working.
    Open you tube from google crome (click on Request to dekstop) then go to full screen mode then press home button.
    Sun90 likes this.
  4. adwaitatre
    Froyo Oct 15, 2017
    adwaitatre , Oct 15, 2017 :
    I am getting error while updating
    updater process end with error 7
    How to solve it?
  5. F_Andrea_Ippolito_ZsRS
    F_Andrea_Ippolito_ZsRS , Oct 15, 2017 :
    To anyone who clean flashed out there, and has a way to measure wakelocks (e.g. gsam, wakelock detector, or others).
    Can you please play a bit with the NFC toggle from the quick settings (on/off some times) and then check after some time if you had a wakelock related to NFC? I got a huge one that kept my OP3 awake all night.
    It look like in the screens and is called:
    NFCService:mEeWakeLock
    If you don't get it with a clean flash, I may consider as factory reset.
    Ps: seems like this update also further reduced touch latency, it feels like the keyboard almost anticipates what I'm about to type :D
  6. G_Taif_Rahaman_qnUB
    Cupcake Oct 15, 2017
  7. Sun90
    Starting Point Expert Community Expert Oct 15, 2017
    Sun90 , Oct 15, 2017 :
    Known issue with TWRP.
    Use stock Recovery
  8. Sun90
    Google it to find more on it.
  9. G_plusone
    Nougat Oct 15, 2017
    G_plusone , Oct 15, 2017 :
    Turn on Airplane mode and then switch it off.
    Try restarting the phone.
    You might have already tried it still give it a try.
    Try posting in the official thread
  10. Ajmal Phoenix
    Donut Oct 15, 2017
    Deactivated User likes this.
  11. F_Muhammed_Amal_gnry
  12. Shrikant23
    Donut Oct 15, 2017
    Shrikant23 , Oct 15, 2017 :
    it's not working for me either... something is missing
  13. Deactivated User
    Oct 15, 2017
  14. Mohil sheth
    Mohil sheth , Oct 15, 2017 :
    serious issues with OS
    1) can not open widget menu..from desktop page
    2) too.much battery drainage
    3) there is no good features that attract and stick to this OS
    4) heating issue is increased..
    5) no icon , theme , gallery , nothing had been changed...so bad please change it
  15. Ankitbhat12345
    Your brain is missing. Everything is working just follow steps given below
    deviantartjr likes this.
  16. Deactivated User
    Oct 15, 2017
  17. Yannis Neris
  18. Deactivated User
    Oct 15, 2017
  19. Lethaljoe
    Honeycomb Oct 15, 2017
    Lethaljoe , Oct 15, 2017 :
    We OP3/3T users are just testing it for you guys with a OP5.
  20. Ankitbhat12345
    Do factory reset
