194
OxygenOS Open Beta 25 for the OnePlus 5 and Open Beta 23 for OnePlus 5T
  1. Patrikkallander
    Eclair Jan 15, 2019
    Patrikkallander , Jan 15, 2019 :
    Or flash magisk uninstaller. Then flash unmodified version of boot image ( Extract it from rom zip) and then flash magisk.
    But i would recommend clean install.
    Usually when you go from Oreo to Pie you can get error in TWRP because of the compatibilty.zip in the Rom zip file.
    But that process seems to have worked for you.
    fcarmona likes this.
  2. fcarmona
    Gingerbread Jan 15, 2019
    fcarmona , Jan 15, 2019 :
    Yes, before install the last Beta, I removed the compatibility.zip from ROM
    Patrikkallander likes this.
  3. Patrikkallander
    Eclair Jan 15, 2019
    fcarmona
    Okey good. I dont know if the last i wrote will have any effect. You couldnt just to a direct install in Magisk manager?
  4. fcarmona
    I can't, every time I reboot, twrp blu_spark or codeworks disapear from my phone :X
  5. Patrikkallander
    Eclair Jan 15, 2019
    Because the root is not there. Its restores the recovery. Have you tried SuperSu?
  6. HardArtiFact
    Eclair Jan 15, 2019
  7. fcarmona
    No, but, after all, reinstall last Beta again and Magisk 18 and not clear cache and works!!!!!!
    Thank you my friend
  8. Patrikkallander
    Eclair Jan 15, 2019
    Ah good :) no problems , you solved it yourself :)
  9. P1512569276852
  10. chethan_gowda_313
    Eclair Jan 15, 2019
    chethan_gowda_313 , Jan 15, 2019 :
    Why don't you people add the audio tuner for Bluetooth devices?....there have been many people asking for it and it's constantly being ignored?....please bring it in the next beta build, it would be really helpful for many 5/5t users
  11. mind_never
    Froyo Jan 15, 2019
    mind_never , Jan 15, 2019 :
    Still not enabling VoLTE/VoWiFi/VC globally by default? :(
    Support for wireguard? :(
    Why the deep Google Duo integration? Compared to other IM apps GD is kind of dead.
  12. fcarmona
    I use v4a module in Magisk
  13. Tcat007
    Honeycomb Jan 15, 2019
    Tcat007 , Jan 15, 2019 :
    I dirty flashed from 9.0.2 to ob23 with no issues other than my battery % was missing. Decided to clean flash, it's back and everything looks good.
    TWRP Bluspark 9.91
    Wiped all except internal
    Flashed ROM, magisk 18, and noverity2
    Wiped caches (swipe)
    Rebooted, setup.
    Rebooted again since first boot was laggy.
    Smooth as silk now.
    RoyxD4 likes this.
  14. NoInspiration
  15. akulasaisandeep
    Eclair Jan 15, 2019
  16. zulrakz
    Donut Jan 15, 2019
    zulrakz , Jan 15, 2019 :
    nice progress.. but i haven't receive the 9.0.1/2 yet.. i'm using 5t and it's unusual not to have it for a long time since releasing.. whats wrong???
  17. Feipu_64
    Cupcake Jan 15, 2019
    Feipu_64 , Jan 15, 2019 :
    Hello ,
    I downloaded open beta 22 on my 5T I went to 'Settings' -' System Update ', I clicked click on the' Settings' icon in the upper right corner, select 'Local update', find the .zip file and click on 'Install 'to confirm. tells me to move the directory file. after downloading the .zip file clicking on it, it says that there is no file. Thanks for your help .
    Filippo
  18. Tcat007
    Make sure the zip is good (click on it to be sure it opens). Put it at root of sd. Local install should find it and install it.
  19. Feipu_64
    i try it and i check ,
    thanks and I give you a feed back ...
  20. fcarmona
    Why don't you download OB 23?
