194
OxygenOS Open Beta 25 for the OnePlus 5 and Open Beta 23 for OnePlus 5T
  1. SyamKG
    Ice Cream Sandwich Jan 16, 2019
    SyamKG , Jan 16, 2019 :
    I use navigation gesture, and it works fine.. I cleared cache from recovery after the update.
  2. Robert.Laffan
    Cupcake Jan 16, 2019
    Robert.Laffan , Jan 16, 2019 :
    Mine also worked for a while but stopped now. I tried clearing cache from recovery already - no joy.
    UPDATE: I had frozen the OP launcher. Unfreezing it solved it. (I use Nova as default)
  3. leonardoafa
    Eclair Jan 16, 2019
    leonardoafa , Jan 16, 2019 :
    Adaptive color for navigation bar, not working properly on whatsapp. When the keyboard pops up on the screen, the navigation bat turns black, and not white as before (on Oreo). When open a conversation window the navigation bar is white, as soon as you tap on the write box and the keyboard pops up, the navigation bar turns black, as you can see on the screen shot below
    Not working example
    working example, on oreo.
    Anyone else facing this issue?
    Any help would be appreciated!
    Edward Mikolenko likes this.
  4. barath_000
    Gingerbread Jan 16, 2019
  5. U1545741558801
  6. J1513405181224
    Donut Jan 16, 2019
  7. U1545741558801
  8. U1545741558801
  9. Fuschy
    Fuschy , Jan 16, 2019 :
    When trying to flash this build Im getting the compatiblity error. How can I fix this? I used to download the zip without the compatibility file, but I cant seem to find one this time..
    ymicky likes this.
  10. Mustasim
  11. Tcat007
    Honeycomb Jan 16, 2019
    Tcat007 , Jan 16, 2019 :
    Update your TWRP to Bluspark 9.91, or other that's pie compatable, then you can leave compatable zip. Or use MixPlorer to remove that zip. I use to use Solid Explorer, but since I tried Mix, that's my default now.
  12. ymicky
    ymicky , Jan 16, 2019 :
    I tried to boot the latest TWRP "twrp-3.2.3-0-20181227-codeworkx-nocompatcheck-cheeseburger" but it doesnt start..
    It does nothing just the notification led is on white
    Edit: Okay, using TWRP for Oreo and removing the file in the Zip has worked.
  13. Gu21
    Eclair Jan 16, 2019
    Gu21 , Jan 16, 2019 :
    Which ROOT and TWRP functional method for this latest beta? ONEPLUS 5T
  14. RedDragon22
    RedDragon22 , Jan 16, 2019 :
    Thanks it worked
  15. PokiX
    Jelly Bean Jan 16, 2019
    PokiX , Jan 16, 2019 :
    Twrp 9.91 and Magisk 18 work fine.
    Rambo15 and fcarmona like this.
  16. Gatotp3
    Gatotp3 , Jan 16, 2019 :
    Root with magisk does not work, always reboot after entering the homepage
  17. PokiX
  18. Gu21
    Eclair Jan 16, 2019
    Could you please send me the twrp link?
  19. G_Grzegorz_Wilczyński_Bt
    G_Grzegorz_Wilczyński_Bt , Jan 16, 2019 :
    I have a problem on the instagram how a message is written, the keyboard obscures what it is writing. I tried to change the keyboard to uninstall applications, to clear the data did not help. Does anyone have such a problem?
  20. rakesh003rakesh
    Eclair Jan 16, 2019
    andreoski likes this.
