194
OxygenOS Open Beta 25 for the OnePlus 5 and Open Beta 23 for OnePlus 5T
  1. Tcat007
    Honeycomb Jan 16, 2019
    Tcat007 , Jan 16, 2019 :
    You can if you want to, but no. Always backup anyway.
  2. fcarmona
    Gingerbread Jan 16, 2019
    fcarmona , Jan 16, 2019 :
    Try doing a reflash and NOT clear cache.
  3. Dhanushekar995
    Cupcake Jan 16, 2019
  4. F1547647820132
  5. fcarmona
    deviantartjr likes this.
  6. fcarmona
    From the oneplus page:
    • How to upgrade system?
      Download the software build for your device on this page. Please back up your data before flashing your device.
      Plug your phone into your computer and copy the downloaded .zip to your phone’s storage. If you’re using a Mac, you can install Android File Transfer for this operation.
      After the .zip file is copied to your phone, go to 'Settings' - 'system update', click the 'settings' icon on the top right corner, choose 'Local upgrade', find the .zip file and click on 'Install' to confirm.
      The update takes about a minute (depending upon the file size), once done reboot your device to boot into the latest Oxygen OS.
  7. F1547647820132
    F1547647820132 , Jan 16, 2019 :
    I'm definitely sure it's the brightness because the level now is always higher than it used to be. But I think the levels have changed I was probably getting the same brightness at lower tweek, as you said it will learn.
  8. sharanjeet4u
    Donut Jan 16, 2019
    sharanjeet4u , Jan 16, 2019 :
    What is supposed to be like truecaller app or something else?
  9. ap279954
  10. ap279954
  11. Sidharth Shrivastav
  12. EvilGrin99
  13. fcarmona
    Eveything work excellent, the phone is smooth and very responsive.
    No problems with wifi, or bluetooth conections.
    ROM usin Magisk is stable. I using modules: magisk hide, v4a.
    I only miss the mock allocations from Oreo.
    And xposed too.
  14. drmvsrinivas
  15. Aziz_Amin_Oneplus
    Jelly Bean Jan 16, 2019
    Aziz_Amin_Oneplus , Jan 16, 2019 :
    No doubt everything is perfect, animations, no lags, very smooth experience and no problems in apps or anything else but one thing is sure straggling that is the battery life, I am 5% down still have to check within this week may be it is mixing up with the apps still early review so just saying as I have come from clean flash from stable version 9.0.2 otherwise Update is awesome and hats off to Oneplus for making and providing this update for us Oneplus 5 and 5t users :)
  16. jay5t
  17. Dr. Robert
    Froyo Jan 16, 2019
    Dr. Robert , Jan 16, 2019 :
    Interesting. I too, have seen the HOME gesture suddenly disappear. But it returned without any effort on my part and has been working fine ever since. Not sure how to duplicate this or if it will recur. I fear it probably will at some point.
    Rakshit_Patil likes this.
  18. jsohamm
    Froyo Jan 16, 2019
    jsohamm , Jan 16, 2019 :
    we havent received 9.0.2 update and u guys started another beta version
  19. shahbaj alam
    shahbaj alam , Jan 16, 2019 :
    On this portion,there was a widget called "OnePlus widget" , showing time and temperature. Now I'm not able to find that. Can anyone tell me whether this widget is available on their 5T Device. Thanks
  20. Shinigami.11
    Donut Jan 16, 2019
    Shinigami.11 , Jan 16, 2019 :
    is it this one ?
