194
OxygenOS Open Beta 25 for the OnePlus 5 and Open Beta 23 for OnePlus 5T
  1. M1535401541418
    Cupcake Jan 16, 2019
  2. shahbaj alam
    Honeycomb Jan 16, 2019
    shahbaj alam , Jan 16, 2019 :
    are you on open beta 23?
    why not showing to me??
  3. M1535401541418
  4. Shinigami.11
    Donut Jan 16, 2019
    Shinigami.11 , Jan 16, 2019 :
    yep, try look if others have the same problem, i dont have an exact solution for you
  5. shahbaj alam
    can you show me the widget section and tell me that widget is available or not?
  6. Dhruv2398
    Donut Jan 16, 2019
  7. Shinigami.11
    Donut Jan 16, 2019
    then you cant get this update, this is a beta update for beta users only not for stable
  8. shahbaj alam
    just installed, have to check for atleast 2 days
    fcarmona likes this.
  9. Mr_Cyrox
    KitKat Jan 16, 2019
    Mr_Cyrox , Jan 16, 2019 :
    You're not recieving it via OTA?
    If you're not running an Open Beta build currently you won't get this 'update'
    You can't flash it, it shows 'Older ROM' error in local update?
    Just continue and ignore it and factory reset afterwards
    You're getting 'failed to update' error?
    Go to .Ota folder and delete all it's contents
    If installing it manually delete the ROM file and download it again
    After that restart the device and try installing it once more
  10. Shinigami.11
    Donut Jan 16, 2019
    yep there it is
  11. shahbaj alam
  12. F_Vansh_Gaonkar_ssjH
  13. Shinigami.11
    Donut Jan 16, 2019
    F_Vansh_Gaonkar_ssjH likes this.
  14. SoumyaMahunt
    Gingerbread Jan 16, 2019
    SoumyaMahunt , Jan 16, 2019 :
    The oneplus messaging app requested internet and wifi access after update, is it for caller identification or oneplus is implementing RCS messaging?? Anyone knows??
  15. F_Vansh_Gaonkar_ssjH
  16. F_Vansh_Gaonkar_ssjH
  17. Shinigami.11
    Donut Jan 16, 2019
    try Germany / Canada that usely works
  18. F_Vansh_Gaonkar_ssjH
    F_Vansh_Gaonkar_ssjH , Jan 16, 2019 :
    bro just txt m on my number my mobile sucks man plz [edited by the moderation, please don't share private info like this on a public forum]
  19. fingerrrrrrr
    Donut Jan 16, 2019
  20. F_Vansh_Gaonkar_ssjH
    its already uploaded??? or more update has to come
    because it's hangs lot
