194
OxygenOS Open Beta 25 for the OnePlus 5 and Open Beta 23 for OnePlus 5T
  1. Ved2rj
    Cupcake Jan 27, 2019
  2. Intruder71
    Lollipop Jan 27, 2019
    Intruder71 , Jan 27, 2019 :
    Err this is a beta rom why are you using it because you don't sound like a beta tester to me..
  3. N1521745873415
    RoyxD4 likes this.
  4. Intruder71
    Thanks for the info.
  5. Navinmholkar
    Gingerbread Jan 27, 2019
    Navinmholkar , Jan 27, 2019 :
    try different version of twrp with full zip not ota file
    bluespark latests version should work
    Intruder71 likes this.
  6. N1521745873415
    N1521745873415 , Jan 27, 2019 :
    After software updating my mobile was strucking with network droping issue, unable to swich to 4g network, could any one help me out from this issue .
  7. d'andrea
    d'andrea , Jan 27, 2019 :
    First of all how come with this update when I search a contact from the dialling page I am shown its mobile numbers twice if the searched contact is on my WhatsApp library? It is a problem I had with my old Samsung Galaxy S2 plus as well, and both now and then it was originated by an update. Can the matter be solved soon? It is unbearable to see four numbers instead of two.
    Secondly, I understand that the graphics' design was maybe tailored for people who have difficulties in short-distance sight, but having just five conversation in the Messages home page is really too less. Obviously more conversations could be shown there, but then the set font would be too tiny and it would really become a problem to read.
    Third, could you please put back symbols instead of explanations of the functions in the contacts high bar and elsewhere, please? And reduce the complexity of the explanations too? As for example in the "Rispondi con messaggio (Answer with a message)" instead of the simple "Rispondi (Answer)" in the messages shortcut.
    Thank you, I hope I will have some explanations soon or that the issues will be takled.
    d'andrea
  8. knManoj
    knManoj , Jan 27, 2019 :
    +1
    All these issues happening with me too from a month now.
    All the basic trouble shooting done. Still same.
    Currently, on latest beta.
  9. Intruder71
    So... ? Factory reset it
  10. knManoj
    Yea done that too. I think this is the issue only in beta. not sure.
  11. Intruder71
    There is no issue I'm running the same beta... The only difference is when pie beta first came I downloaded it booted to recovery, cleared system partition then flashed the rom then cleared cache and rebooted..
    RoyxD4 likes this.
  12. knManoj
    Hmm.. Difficult to understand why its happening with few users
  13. Intruder71
    Because they didn't do what I did
  14. PokiX
    Jelly Bean Jan 27, 2019
    PokiX , Jan 27, 2019 :
    For the first point, did you check in wifi preferences the first option?
    uzair19 likes this.
  15. SevenOptimus
    Froyo Jan 27, 2019
    SevenOptimus , Jan 27, 2019 :
    Yes. forums.oneplus.com/feedback
  16. RoyxD4
    Froyo Jan 27, 2019
    RoyxD4 , Jan 27, 2019 :
    when i clean the task manager the apps doesnt close at all; in setting i set deep clean but dont force stop running.
  17. Tcat007
    Honeycomb Jan 27, 2019
    Tcat007 , Jan 27, 2019 :
    When you reply to a post, hit the "upload file" button. Then the "choose file" button, and click on the file you want upload. Then post. I use Chrome, not the app.
  18. F_Gupta_Vipul_WafK
    ravikrcsia likes this.
  19. Tcat007
  20. Intruder71
    Another one thinks it's Facebook or some other form of social media
    B1527348897071 likes this.
