194
OxygenOS Open Beta 25 for the OnePlus 5 and Open Beta 23 for OnePlus 5T
  1. F_Gupta_Vipul_WafK
    Cupcake Jan 27, 2019
    F_Gupta_Vipul_WafK , Jan 27, 2019 :
    I'm not on open it's a official version. I got update yesterday.
  2. bartekc00
    Gingerbread Jan 27, 2019
    bartekc00 , Jan 27, 2019 :
    Wrong topic then
    Intruder71 likes this.
  3. B1527348897071
    Eclair Jan 27, 2019
  4. ashish.rawat.pr
    ashish.rawat.pr , Jan 27, 2019 :
    Anyone facing issue with Outlook app? Updated to latest os on Friday, had outlook app update on Saturday and its not working since then..
    Any help anyone can extend...?
  5. B1527348897071
    Eclair Jan 27, 2019
    B1527348897071 , Jan 27, 2019 :
    can you explain more about your issue? connection , UI, crashes. etc?
  6. ashish.rawat.pr
    Thanks for your response. I had issues, so I uninstalled, and re-installed, when trying to log in, all it says at the first page is 'an error occurred'. No further notification.
    I tried adding outlook as device acct app, it gives same error.
    Tryo g to add o365 email id.
  7. Ved2rj
    Ved2rj , Jan 27, 2019 :
    then what should i do
  8. Intruder71
    Lollipop Jan 27, 2019
    Intruder71 , Jan 27, 2019 :
    Not here joined the beta path in the first place as you would need to format your system partition to return to stable..
  9. Ved2rj
    Intruder71
    Not here joined the beta path in the first place as you would need to format your system partition to return to stable..​
    you mean i should format my 5t
  10. Intruder71
    Yes but if I was you I would back everything up first... Its not as painful as it sounds...
  11. Ved2rj
    when stable update will be available in India ?
  12. Intruder71
    It's already available get it from downloads..
  13. Ved2rj
    how can i know if my udate was beta or stable ?
  14. Intruder71
    Because one is called beta and the other stable .. Go look in the downloads..
  15. Ved2rj
    where is download
  16. Intruder71
    Does someone have to dress you in a morning too?
    downloads.oneplus.net
    PokiX likes this.
  17. Ved2rj
    I think i have updated stable update but i dont like its speed
  18. B1527348897071
    Eclair Jan 27, 2019
    Ved2rj
    how can i know if my udate was beta or stable ?​
    the about phone section will give a version number for stable . or say BETA if it's beta. mine looks like BETA O2
  19. Ved2rj
    mine is 9.0.3
  20. PokiX
    Jelly Bean Jan 27, 2019
    PokiX , Jan 27, 2019 :
    Then it could be that you are not in the correct thread. Like most of last posters actually ahah
    B1527348897071 likes this.
