194
OxygenOS Open Beta 25 for the OnePlus 5 and Open Beta 23 for OnePlus 5T
  1. B1527348897071
    Eclair Jan 27, 2019
    B1527348897071 , Jan 27, 2019 :
    look at mine
    to become beta go to this link
    backup your important data (all of it) (eventually beta builds can delete your data without warning)
    https://www.oneplus.com/support/softwareupgrade
    select your phone type
    select Beta Build
    download the ZIP file
    go to recovery mode
    click install update locally
    select zip file.
    IMPORTANT: Beta can have non functioning parts, or broken functions depending on the device
    IMPORTANT: you cannot go back to stable unless you flash the entire phone back to stock firmware.
    Notice: if you don't know what firmware, root, or flash is. Read up on rooting NANdroid backups as you might break your phone otherwise ^^"> I don't want to feel guilty if you do.
    deviantartjr likes this.
  2. smitbhagat
    Honeycomb Jan 27, 2019
    smitbhagat , Jan 27, 2019 :
    Anyone having trouble opening Google Lens from the camera app on the latest beta 25 on Op5?
    B1527348897071 likes this.
  3. B1527348897071
    Eclair Jan 27, 2019
    just tested it on OP5 With Beta 25 (latest). works fine on my end. try to reset camera app maybe?
  4. smitbhagat
    Honeycomb Jan 28, 2019
    smitbhagat , Jan 28, 2019 :
    B1527348897071
    just tested it on OP5 With Beta 25 (latest). works fine on my end. try to reset camera app maybe?​
    Tried everything, no luck
  5. Tcat007
    Tcat007 , Jan 28, 2019 :
    Did you try testing it in Photos app?
  6. yaswanth.p1
    Gingerbread Jan 28, 2019
  7. Abhig11
    Donut Jan 28, 2019
    Shivam_sakral likes this.
  8. Negi_lokesh
    Donut Jan 28, 2019
    Negi_lokesh , Jan 28, 2019 :
    i have already reported this via report any bug feature But wanted to know about any solution or anyone else facing the same issue , my gboard(google keyboard) switches it theme to default when battery saver turns on at 15% every time. to reproduce the same bug keep any theme apart from the default one and as soon as your battery will hit Below 15% , gboard will change its theme to the default one automatically. it wont happen if you manually turn on battery saver. all apps updated to latest version and i am on the latest beta. Any one facing this issue?
  9. Tcat007
  10. Negi_lokesh
    Donut Jan 28, 2019
    i agree, but sometimes when you are out and can't charge it, you got to change the theme back to whatever it was. extra pain
  11. iharshjjain
    Ice Cream Sandwich Jan 28, 2019
  12. Mr_Cyrox
    KitKat Jan 28, 2019
    Mr_Cyrox , Jan 28, 2019 :
    You should hide/remove phone numbers from some "bad" people that like to collect that information
  13. Intruder71
    Lollipop Jan 28, 2019
    Intruder71 , Jan 28, 2019 :
    Can't be no worse than oneplus giving it away to some Chinese company lol
  14. Mr_Cyrox
    KitKat Jan 28, 2019
    True but better not give up hope and broadcast your friends/family/other phone numbers to a public forum...
    Intruder71 likes this.
  15. Andy L.
    Andy L. , Jan 28, 2019 :
    Same here, just noticed I had this problem as well a day or two ago after seeing your reply. I'm on 5T and don't have the standalone Google Lens app installed. Tapping on the icon just makes the screen go blank for a second and go back to the Camera app. I've tried clearing Camera app storage but it didn't help.
  16. lx6mount
    Cupcake Jan 28, 2019
    lx6mount , Jan 28, 2019 :
    Experiencing some bluetooth issues, my BeatsX's(and other bluetooth speakers) mic is not working sometimes.
    Other updates are good.
  17. B1527348897071
    Eclair Jan 28, 2019
    B1527348897071 , Jan 28, 2019 :
    I'm assuming you are beta 25 user too?
  18. B1527348897071
    Eclair Jan 28, 2019
  19. Javed Anwar
  20. yaswanth.p1
