194
OxygenOS Open Beta 25 for the OnePlus 5 and Open Beta 23 for OnePlus 5T
  1. B1523700909321
    Cupcake Feb 2, 2019
  2. B1527348897071
    Eclair Feb 2, 2019
    B1527348897071 , Feb 2, 2019 :
    sounds very similar to the 6T problem following the update, I read in some places that a factory reset resolves this. however... trying solutions without understanding a problem first is not ideal. try using an app such as (Automate) to disable certain components you suspect of battery draining (I e. Camera or service that Battery usage monitors highlight) and see if this helps you go around until the official patch comes out.
  3. R1546621747488
    Donut Feb 2, 2019
  4. akvel
    Donut Feb 5, 2019
    akvel , Feb 5, 2019 :
    Hi! My cards widget is totally not working. Don't know the reason, but this happened couple of updates ago. I'm on the latest beta now (23 for OP5T). The widget is just blank and doesn't even open any app.
  5. Waveform Modifier
    Marshmallow Feb 5, 2019
    Waveform Modifier , Feb 5, 2019 :
    Sorry to break it to you. The latest Open Beta for the 5T is version 24.
  6. Mohammad Anas
    Cupcake Feb 6, 2019
    Mohammad Anas , Feb 6, 2019 :
    hi brother, I'm oxygenos version 9.0.3 user. So how can I update my phone into OxygenOs open beta 23 version? please inform me ASAP
  7. nixie21
    Gingerbread Feb 6, 2019
    nixie21 , Feb 6, 2019 :
    Anyone?
  8. paulomodesto
    Jelly Bean Feb 7, 2019
  9. C1547913158126
    Cupcake Feb 7, 2019
  10. Haliwada
    Cupcake Feb 8, 2019
    Haliwada , Feb 8, 2019 :
    Very Cool Update from 1 plus team thanks for ur support .but after the update all of the apps keep crashing and need to be closed or says wait for respond . please fix the problem at earliest .thanks
  11. jay5t
    Gingerbread Feb 11, 2019
    jay5t , Feb 11, 2019 :
    There is a folder in my internal folder called FaceUnlockDebug and there are loads of caches files that keep building up no matter how many times i delete them. I have unticked the option in the OnePlus log kit, but the issue still persists. Can anyone help me out
  12. Tcat007
    Honeycomb Feb 11, 2019
    Tcat007 , Feb 11, 2019 :
    Settings/display
  13. paulomodesto
    Jelly Bean Feb 11, 2019
