421
OxygenOS Open Beta 25 for the OnePlus 6 and Open Beta 17 for OnePlus 6T
  1. n00blit likes this.
  2. n00blit and Owski97 like this.
  3. Starcommander
    OnePlus Accessory Tester Oct 17, 2019
    Starcommander , Oct 17, 2019 :
    Hey actually its a bug. Only one network at a time but this time both were showing together
    NodePoint and Maverick2.0 like this.
  4. wizard19999
    Gingerbread Oct 17, 2019
  5. Pankaj_88
    Froyo Oct 17, 2019
    Pankaj_88 , Oct 17, 2019 :
    this is perfectly fine. doesn't look like any bug to me. unless you say you got both networks without switching on dual 4G.
  6. B_Wrath
    Junior Moderator Junior Moderator Oct 17, 2019
    B_Wrath , Oct 17, 2019 :
    Definitely:rolleyes:
    Nope. Dual active data connection is not possible in OP phones. All are dual Sim dual standby.
    Yup. It is a bug. Usually happens when you switch data from one sim to another and the status bar is slow to change. Had this bug since OP3 days. It's still present in my OP6.
  7. efks
    Ice Cream Sandwich Oct 17, 2019
  8. vishrutjha
    Honeycomb Oct 17, 2019
    vishrutjha , Oct 17, 2019 :
    I use Lawnchair Launcher and it works fine for me. Maybe your launcher of choice has the problem
  9. vishrutjha
    Every new Android iteration has some kind of a promise like this... Doze and Aggressive doze. It's not that substantial an improvement.
  10. efks
  11. aresza20
    Donut Oct 17, 2019
    aresza20 , Oct 17, 2019 :
    maybe someone from the oneplus crew will inform you how long we will wait if the new beta is to be this month, so when will it be released, this week or the next or in 2 weeks?
  12. ngydat
    Lollipop Oct 17, 2019
  13. vlc_marcos
    Donut Oct 17, 2019
    vlc_marcos , via OnePlus 6T , Oct 17, 2019 :
    You are using the H2O right?
    that looks a good time. is it all on 4g? how many accounts do you have syncing?
    ok curious to see the oos 10 in the op6t
  14. An.I.Am
    Jelly Bean Oct 17, 2019
    Starcommander and Artemus like this.
  15. E1539310857243
    Cupcake Oct 17, 2019
    E1539310857243 , Oct 17, 2019 :
    Hi
    I am using beta version on oneplus 6
    But I have been facing lot of intermittent network issues. Same network on different phone is good.
    is anyone facing these issues??? please help me
    thanks
  16. Cervantes
    Moderator Moderator Oct 17, 2019
    Cervantes , Oct 17, 2019 :
    Hi
    Please, You read the first post
    *"The beta or update thread is a thread of questions and/or commentary"*
    Please, You can use the search engine before opening a new thread
    Thread merged
  17. rhyd1am
    KitKat Community Expert Oct 17, 2019
    rhyd1am , via OnePlus 6T , Oct 17, 2019 :
    Have you tried another sim in your OP6 to see if you have the same problems? Or tried to reset network settings?
  18. Mr.Wraul
  19. Owski97
    Owski97 , via OnePlus 6T , Oct 17, 2019 :
    press long at the home screen
  20. Rifat K Saif
    Rifat K Saif , Oct 17, 2019 :
    I'm having an issue from last evening. As I restarted the phone, it asked for Factory Reset, I did that because it wasn't turning on. Then as the Reset was completed, the phone changed to the very first menu while unboxing. And as i wanted to proceed the SIM was not detected and so wasn't the WiFi got connected. Any suggestions?
