422
OxygenOS Open Beta 25 for the OnePlus 6 and Open Beta 17 for OnePlus 6T
  1. Leandro161288
    Froyo Sep 4, 2019
    Leandro161288 , Sep 4, 2019 :
    what do you mean? that the android q version that manu say it will be beta or the final version?
    #81
  2. Myownoneplus6T
    Froyo Sep 4, 2019
    Myownoneplus6T , Sep 4, 2019 :
    prasun2
    from last 2 days my fon facing network issue ,sim 2 not detect single signal and so sim one slot also showing poor network,pls fix it soon.Im not able to use my data and even not clear voice on call on one plus 6t.​
    me too facing this problem with my 6T last 1 mnth ☹️ plz fix this,
    #82
    smileysibi and prasun2 like this.
  3. Scherpenseel
    KitKat Sep 4, 2019
    #83
  4. Scherpenseel
    KitKat Sep 4, 2019
    Scherpenseel , Sep 4, 2019 :
    Why asap? I rather have a "able to use as a daily driver-update" than a rushed out update that doesn't work.
    #84
  5. Dhineshkaran
    Eclair Sep 4, 2019
    #85
    Mike_Jiang likes this.
  6. Scherpenseel
    KitKat Sep 4, 2019
    DON'T install beta if you're so scared to lose data... It's a beta and beta's are used for testing the OS and new features. Always a chance to lose data.
    #86
    MercyKiller69 likes this.
  7. ShreyasAradhyaP
    Cupcake Sep 4, 2019
    ShreyasAradhyaP , Sep 4, 2019 :
    Definitely usable as a daily driver and battery life is excellent as always! Definitely go for it [e]1f44d[/e]
    #87
  8. 18aniruddha
    Gingerbread Sep 4, 2019
    18aniruddha , Sep 4, 2019 :
    if you installing beta you won't lose any data but if you move from Beta to Stable then you will lose your data
    #88
  9. B_Wrath
    Marshmallow Sep 4, 2019
    B_Wrath , Sep 4, 2019 :
    You can't say that with certainty. Some glitch may lead to bootloop and end up in wiping everything.
    #89
  10. G_Akil_Akku_wxCx
    Froyo Sep 4, 2019
    #90
    jasemanONE likes this.
  11. 18aniruddha
    I've done it many times and didn't face any issues while installing beta.
    moving from beta to stable causes data loss
    #91
  12. pkadavid
    Cupcake Sep 4, 2019
    pkadavid , Sep 4, 2019 :
    That could happen with a stable release as well. You should always have a backup before any update. However, the chance of losing data is low.
    #92
  13. B_Wrath
    Even I have done it plenty of times. What I meant is an extreme case. P
    #93
    Starcommander likes this.
  14. S1528662225243
    Donut Sep 4, 2019
    S1528662225243 , Sep 4, 2019 :
    If I stay on beta, will the next OB 1 for android 10 just come as an regular update ( like lets say op26 ) , or will it require something else?
    #94
  15. 18aniruddha
    if you stay on beta you will recieve future beta updates via OTA
    #95
    S1528662225243 likes this.
  16. G_Huynh_Tinh
    G_Huynh_Tinh , Sep 4, 2019 :
    That's good. Can't wait and thanks for infos.
    #96
    F1578066411459 and petertinh like this.
  17. filla17
    Froyo Sep 4, 2019
    filla17 , Sep 4, 2019 :
    will we get Android 10 official update automatically after this open beta 25 with out loosing data and if I will flash this update over stable, will I loose data?
    #97
  18. 18aniruddha
    if you flash this beta on stable you won't lose any data.
    if you go back to stable from beta you will lose your all the data
    #98
  19. filla17
    Froyo Sep 4, 2019
    #99
  20. 18aniruddha
    if you are on beta you will get only beta updates via OTA.
    if you are on stable you will get only stable updates via OTA.
