421
OxygenOS Open Beta 25 for the OnePlus 6 and Open Beta 17 for OnePlus 6T
  1. rhyd1am
    Jelly Bean Sep 27, 2019
    Caomhin likes this.
  2. Starcommander
    Lollipop Sep 27, 2019
    Starcommander , Sep 27, 2019 :
    While using the thinder purple live wallpaper, the wallpaper sometimes load in the upper part of screen, rest is black. Sometimes there is a purple rectangular box. Its onlu happening eith the thunder purple wallpaper. Rest all wallpapers are fine. A screen lock solved the issue temporarily again it appears
    Alxhn likes this.
  3. nedamdam
    Eclair Sep 27, 2019
    nedamdam , Sep 27, 2019 :
    Thank you for the reply. Not rooted, no magisk. Stock all the way.
    Thank you for the reply. No root. Stock. Did not try reset. Would not like to reset as I would have to setup million things from start... (Like my watch, banks etc)
  4. Trikz2000
    Froyo Sep 27, 2019
    Trikz2000 , Sep 27, 2019 :
    Try checking the play store device certification status. If even that checks out, then I'm afraid you're going to have to wipe it.
    U1567753796791 likes this.
  5. nedamdam
    Eclair Sep 27, 2019
    nedamdam , via OnePlus 6T , Sep 27, 2019 :
    Certification status is ok. How do you know that a wipe will help ?
  6. Trikz2000
    Froyo Sep 27, 2019
    I suggested a wipe because it usually sorts out most problems. So unless you were having issues from the beginning i.e ,since the first you started using the phone, it might clear something that we have overlooked/not thought of. It's a clean start. Also because it doesn't seem to be an issue for the others on both stable and beta.
  7. rhyd1am
    rhyd1am , via OnePlus 6T , Sep 27, 2019 :
    Forget my previous reply, not working for me either now. I recently changed the dpi though, so not sure if that's causing it to have stopped working for me.
  8. Trikz2000
    Froyo Sep 27, 2019
    I can only guess without the details bro. there could be any reason. the wipe is the most direct (albeit not so easy to deal with) solution. There are a number of factors, any of which could be a reason. It could be that the same account is running on another phone (happened to a relative), there could be an interfering app or anything. I'm not saying it's the only option, but I'm saying 99% of the time it works. I agree setting up the phone again is hard tho.
  9. charanrockstar
    Eclair Sep 27, 2019
  10. vishal884
    Cupcake Sep 27, 2019
    vishal884 , Sep 27, 2019 :
    OnePlus 6 is having Carrier Aggregation Problem on Jio it works with 1800mhz + 850mhz band but doesn't work with 2300mhz +1800mh +850mhz band so when the phone gets connected to 1800mhz or 850mhz then only the 4G+ Carrier Aggregation works and if the phone connect to 2300mhz band the phone doesn't aggregate the 3 bands together so 4G+ won't work I tried disabling 2300mhz from app called network signal guru(root) to check and disable the band 2300mhz found the problem this problem is not there on OnePlus 7 on my brothers device on band 2300mhz 4G+ work properly on same area on Jio network so this is clear OnePlus 6 is having Carrier Aggregation Problem on Band 40 -2300mhz and can be fixed by a software or firmware patch now it's on OnePlus Team if they wanna fix this for us i m afraid they won't coz now the device is 1.5 year old and they are busy building OnePlus 8 i guess coz every 6 months new device get popped up and we feel we got cheated pls OnePlus fix it for us we have very network speed it will help in improving speed I have attached screenshot of NSG app https://imgur.com/gallery/Ecu65LC
    Xcutioner likes this.
  11. jshaw49
    Donut Sep 27, 2019
    jshaw49 , Sep 27, 2019 :
    No one has the update. It hasn't been released.
  12. R1561523048031
  13. Xcutioner
    Honeycomb Sep 27, 2019
  14. Xcutioner and R1561523048031 like this.
  15. Starcommander
  16. Gzzzy
    Froyo Sep 27, 2019
    Gzzzy , Sep 27, 2019 :
    What's the build version of your chrome
    sunny.Mehra.op6 likes this.
  17. Starcommander likes this.
  18. Alxhn
    Gingerbread Sep 28, 2019
  19. efks
