192
OxygenOS Open Beta 26 for the OnePlus 5 and Open Beta 24 for OnePlus 5T
  1. davidepica
    Donut Jan 29, 2019
    davidepica , Jan 29, 2019 :
    But is this a problem with the OnePlus phone app? Why do you want to format your system? Do not just uninstall the app and install, for example, Google phone? There are articles that talk about this Spy app?
    Ravi BINAVAT likes this.
  2. suryaraya
    Froyo Jan 29, 2019
    suryaraya , Jan 29, 2019 :
    I got this layout a long time ago from pie update it's frustrating I was not able to find a solution for this
  3. AbhilashSaikia
    The Lab - OnePlus 8 Pro Reviewer Jan 29, 2019
  4. S1548750775905
    Cupcake Jan 29, 2019
    S1548750775905 , Jan 29, 2019 :
    Hi,
    I have recently upgraded to Open Beta 26 and since it is upgraded, phone ringtone is not working.
    please get this issue resolved.
  5. Intruder71
    Lollipop Jan 29, 2019
    Intruder71 , Jan 29, 2019 :
    It's not uninstalable it sits lurking in the systems partition and it's not the dialler
  6. EdwardM290
    Eclair Jan 29, 2019
    EdwardM290 , Jan 29, 2019 :
    Sure. Now I'll explain:
    -download your recovery from OnePlusdownloads in the "OnePlus switch" section. (recovery for the 5T OB channel is: http://oxygenos.oneplus.net.s3.amazonaws.com/recovery.img)
    then:
    -go to fastboot, and execute the command: fastboot flash recovery op5trecovery.img (the recovery's name could change, this is just an example)
    -then reboot to recovery, wipe all data and factory reset, and then flash your system.
    IF THIS ↑↑↑ DOESN'T WORK TRY:
    -go to fastboot and: fastboot oem lock (this will wipe all and lock bootloader)
    -then go back to fastboot and unlock it again with: fastboot oem unlock, select yes when it asks you.
    -then flash twrp codeworkx version.
    -when you're in twrp, perform a total wipe, then reboot to recovery.
    -now connect your op5t to pc, and transfer the OXYGENOS OREO version (don't worry, we'll upgrade to pie in a sec) because if you try to directly flash pie, it'll give you a Treble error, so you would be stuck. Flash oreo and reboot.
    -set up your phone, then download OB24 for your 5T from OnePlusdownloads and flash it in the recovery
    -Done!
  7. EdwardM290
    Eclair Jan 29, 2019
    have patience, it's a unusual event that a 2016 device receives Android Pie[e]1f602[/e] So you're lucky, I can understand your joyness and I know you can't wait, but please don't stress developers
  8. AbhilashSaikia
    AbhilashSaikia , Jan 29, 2019 :
    Which Xiaomi device are you talking about?
    Mi A1 supports dual VoLTE due to the presence of an external modem.
    Brother, if you know that SD835 doesn't support it, why are you complaining about "getting the feature through an update"?
    Ravi BINAVAT and Intruder71 like this.
  9. G_Rohit_Sarna
    Gingerbread Jan 29, 2019
    G_Rohit_Sarna , Jan 29, 2019 :
    Not complaining I wasn't knowing it had an external modem to support it being a 15k phone u can't expect it to be future proof
  10. Intruder71
    Google broken? that would have told you without looking silly
  11. Ragul kanna wear
    Froyo Jan 29, 2019
  12. G_Rohit_Sarna
    OK fine thanx for ur suggestion [e]1f60c[/e]
  13. Intruder71
    Right.... Time to downgrade a couple of versions since I proved my phone updated OK meaning its doubtful the full rom is an issue... Time to get rid of the sneaky spying software none of us agreed to that reports home..
  14. fkfdi
    Eclair Jan 29, 2019
    Ravi BINAVAT and Imrohit786 like this.
  15. Intruder71
    There isn't one if your in India, blame the perverts
  16. AbhilashSaikia
    If you don't want to use that feature you can always turn it off.
    Yes I agree that it's a 3rd party company. Some basic data is always collected, whatever company it is!
    Ravi BINAVAT and deviantartjr like this.
  17. AbhilashSaikia
    Xioami is a good brand too. Maybe they thought of it beforehand.
    Ravi BINAVAT and G_Rohit_Sarna like this.
  18. Shubham.agarwal259
    Shubham.agarwal259 , Jan 29, 2019 :
    hey bro,
    when k play pubg mobile game . as we know it is an online gaming i have permitted the app for microphone but the mike dont work many times . please solve this issue.
  19. AbhilashSaikia
    Any other way to change the region?
  20. marc_hahn
    Froyo Jan 29, 2019
    marc_hahn , Jan 29, 2019 :
    I don't have it. But this morning my OP5T notified that I have an update, but i think that has been removed cause that was causing some important bugs. I will be waiting until that will be corrected.
