192
OxygenOS Open Beta 26 for the OnePlus 5 and Open Beta 24 for OnePlus 5T
  1. Tcat007
    Honeycomb Jan 29, 2019
    Tcat007 , Jan 29, 2019 :
    Check XDA. Download and install, no issues.
  2. Q1545504703112
  3. Tcat007
    I never had that issue. Clean flash or factory reset if you're having issues. (ie: wipe cache, data)
  4. Q1545504703112
    Q1545504703112 , Jan 29, 2019 :
    I've tried everything. So many people are having the same issue as me
  5. Mr_Cyrox
    KitKat Jan 29, 2019
    Mr_Cyrox , Jan 29, 2019 :
    But yet many aren't having that issue
    PokiX likes this.
  6. Q1545504703112
    Maybe not in OB 25 but most people are having it on 9.0.3 on stable
  7. Mr_Cyrox
    KitKat Jan 29, 2019
    Well this thread is for OB 26/24 so talk about that build not stable
    deviantartjr likes this.
  8. Q1545504703112
    Yeah, that's why I was asking if ob 26 still has the lagging issue, because some people said it was ok on open beta 25
  9. Mr_Cyrox
    KitKat Jan 29, 2019
    If it was ok in OB25 what makes you think it will be worse in OB26?
    The only way you can make sure is to update...
    No matter what anyone says your experience might be different...
    For example:
    I updated to OB 26 via OTA incremental and didn't get my device bricked but on the other hand some people had there devices bricked in the process...
  10. Tcat007
    Maybe a 5 issue? I've had no issues on 9.0.3 or ob24, 5t. But I never use ota.
  11. siddierockin
    Cupcake Jan 29, 2019
    siddierockin , Jan 29, 2019 :
    I was able to install the Android Pie update on my phone and it looks awsum. It's as smooth as can be. But after 2 days of buttery smooth usage my OP5 has started signs of bugs. The phone hangs while using WhatsApp and Fb app. Also the shortcut icons in the notification bar stops responding and then I have to restart my phone to fix this bug. Love the look and feel of the launcher. Though no improvement s in camera quality.
    crishurazvi likes this.
  12. Petre
    Eclair Jan 29, 2019
    Petre , Jan 29, 2019 :
    Ok, So my device got bricked with the update. I got home now and tried to fix it. From fastboot I can't enter recover (I get a blank screen only). I can't flash a recovery since the bootloader is locked. I can't unloack the bootloader since I can't reach the OS. Any ideas on how to fix my phone? :)
  13. Mr_Cyrox
    KitKat Jan 29, 2019
    Read a few posts up
    Or some pages...
  14. MarioZuniga
  15. MarioZuniga
  16. tafe_tv
    tafe_tv , Jan 29, 2019 :
    I have the same problem. But your steps doesnt work at my op5t. there is no option to set english language. I can just go to recovery mode but than the problem is it switch it self off
  17. SHIVAM.RAVE
    Donut Jan 29, 2019
    SHIVAM.RAVE , Jan 29, 2019 :
    my device got bricked and had to use unbrick tools and thus losing all the data!! which i had not backed up thinking it was a small update!! great work oneplus
  18. Q1548687462812
    Q1548687462812 , Jan 29, 2019 :
    so what can be done
  19. Tcat007
    Everyone should learn to install custom recovery. It makes life so much easier. Can do a backup of the whole ROM in less than 2 minutes. Can wipe whatever is needed (clean flash or dirty flash). Can switch between stable and beta easily by restoring a previous build (or clean flashing). I back up all partitions anytime I upgrade anything and move bu to cloud or PC once a week. Probably Overkill, but have never lost anything. I used system updater once, but even then moved file out of ota folder and clean installed.
    Yeah, OnePlus ota should be much better and more reliable, but once something is messed up on the phone, it may not go away without a factory reset or clean install.
  20. F_Timmy_Smith_UXcn
    Eclair Jan 29, 2019
    F_Timmy_Smith_UXcn , Jan 29, 2019 :
    if people don't fully understand what they're doing and how to recover from any sort of problem then why should they blindly go into flashing beta software..
    I don't know shit about fixing my car so if I try then I probably going to **** it up and it will cost me money to fix.
