192
OxygenOS Open Beta 26 for the OnePlus 5 and Open Beta 24 for OnePlus 5T
  1. tafe_tv
    Cupcake Jan 29, 2019
    tafe_tv , Jan 29, 2019 :
    same problem. If you know how let me know. Please :) I can't see any good solutions here
  2. T1520960676504
    T1520960676504 , Jan 29, 2019 :
    yes exactly..i faced the same issue..i had to flash my device and i loss all my data which was very important for me.
  3. MarioZuniga
    MarioZuniga , Jan 29, 2019 :
    the oneplus team was unable to solve it and told me that I had to pay to solve a problem update...
  4. MarioZuniga
  5. PokiX
    Jelly Bean Jan 29, 2019
    PokiX , Jan 29, 2019 :
    Or simply if people can't read at least the last pages of this thread...
  6. Sam Nakamura
    Ice Cream Sandwich Jan 29, 2019
    Sam Nakamura , Jan 29, 2019 :
    So as software "developer" & "consultant" you tend to use beta releases without backing up your data? I hope that's not what you suggest to your customers...
    backup, backup, backup! is the lil' dev/consultant 101, also reading the OP would help - disclaimers regarding instabilities are right there - only thing more annoying than a failed build is a user blaming the OEM for their own faults! Dang, that's embarrassing, especially since you should have known better and if you are really a professional you will agree!
  7. Tcat007
    Honeycomb Jan 29, 2019
    Tcat007 , Jan 29, 2019 :
    These are my backups on my PC. If you're a "novice", you probably shouldn't be messing with beta. But it's not that hard to learn just enough to get in trouble. XDA can get you out of almost any issues. If don't know how to install custom recovery, you should probably just factory reset and just use ota.
    Sam Nakamura and deviantartjr like this.
  8. Mr.Avi@
    Donut Jan 29, 2019
    Mr.Avi@ , Jan 29, 2019 :
    after update op24 my 5t device fingerprint sensor did not work sometime .anyone same issue
    R1512274214831 likes this.
  9. Sem_Cornelissen
    Sem_Cornelissen , Jan 29, 2019 :
    is there any update how to fix this ? after i downloaded the last beta update my phone won't turn on anymore ??
  10. doom71
    Gingerbread Jan 29, 2019
    doom71 , Jan 29, 2019 :
    READ!!!! All over this thread is the solution for your probleem. Use the MSM tool.
  11. Tcat007
  12. Juampii17
  13. PokiX
    I haven't had any lags. Since Marshmallow I think.
  14. Tcat007
  15. Juampii17
    Juampii17 , Jan 29, 2019 :
    marshmallow in op5? didn't it came with Nougat? and I'm talking about the common known lag issues that came with pie since first build for op5/5t
  16. Tcat007
    No lag on pie or Oreo. Pie is actually smoother.
  17. PokiX
    It might be common known but again: I've had zero lags.
  18. Juampii17
    i had that experience too first days. then after leaving the screen to rest for 2-3 seconds and trying to scroll lags a lot for a sec and also after playing some games for quite a time the ui works badly
  19. PokiX
    I'm using Pie since first day and never experienced this.
    So it must come from some of your apps or an interaction with them.
    If you start from factory reset without restoring apps, you will get a comparable software configuration as mine so you will have no lags. (Note that I have loads of apps)
    We can't really help remotely until someone tries a few basic stuffs.
    Tcat007 and Juampii17 like this.
  20. naveen1008
