192
OxygenOS Open Beta 26 for the OnePlus 5 and Open Beta 24 for OnePlus 5T
  1. T1511077264236
    Cupcake Feb 2, 2019
    T1511077264236 , Feb 2, 2019 :
    phone is lacking so much while using the app what to do what may be the reason of lacking the phone suggest something
  2. vinay 5t
    Gingerbread Feb 2, 2019
    vinay 5t , Feb 2, 2019 :
    download same bulid and install
  3. TheRealGamer
    Lollipop Feb 2, 2019
    TheRealGamer , Feb 2, 2019 :
    Sorry to interrupt, But I've seen this " Ok " In every Beta Post !
  4. rajat.tyagi19
    Cupcake Feb 2, 2019
    rajat.tyagi19 , Feb 2, 2019 :
    Phone freezes very often. camera freezes, dialer freezes and many other apps also freezes very frequently.
    Wish I haven't updated to Android 9 for 5t
    Dhruvit Jain likes this.
  5. Z1549082853052
    Cupcake Feb 2, 2019
  6. sunny.spidy
    Ice Cream Sandwich Feb 2, 2019
    sunny.spidy , Feb 2, 2019 :
    OnePlus has halted the rollout of the latest OxygenOS Open Beta updates for the OnePlus 5 and OnePlus 5T after some users complained that the new versions bricked their devices.
    check news online.
  7. sunny.spidy
  8. sunny.spidy
    OnePlus has halted the rollout of the latest OxygenOS Open Beta updates for the OnePlus 5 and OnePlus 5T after some users complained that the new versions bricked their devices. The Chinese company also pulled the latest OxygenOS Open Beta updates for the OnePlus 6 and OnePlus 6T to avoid any conflicts. The company in a forum post on Wednesday acknowledged that it received user reports of update failure and bricking of the OnePlus 5 and OnePlus 5T after installing the new OxygenOS versions that were released earlier this week. It also provided a workaround for affected users to help them recover their OnePlus phones. While the OnePlus 5 received the OxygenOS Open Beta 26 and OnePlus 5T got the Open Beta 24, the OnePlus 6 and OnePlus 6T received the Open Beta 12 and Open Beta 4 versions, respectively.
  9. Q1547740616261
    Cupcake Feb 2, 2019
    Q1547740616261 , Feb 2, 2019 :
    Any one can help ,after downloading latest updates for 5t ,I am not able download any app, not able to update app also
  10. rajan_parmar
    Cupcake Feb 2, 2019
    rajan_parmar , Feb 2, 2019 :
    Is this beta version released with these solutions...(1) Call connect and end vibration (2) Camera shutter sound not getting off ???
  11. MJ_Vikram
    KitKat Feb 2, 2019
    MJ_Vikram , Feb 2, 2019 :
    camera shutter sound is not bug it's by design by oneplus team..
  12. rajan_parmar
    Cupcake Feb 2, 2019
    Yes, Vikram I know very well. But what will you call that, before beta 24 version the shutter sound can be disabled by an option in camera app, but now can't....
  13. G1520844337310
    Froyo Feb 2, 2019
  14. Joehad83
    Honeycomb Feb 2, 2019
    Joehad83 , Feb 2, 2019 :
    I think you should have never been on beta if you don't know what to do.
    if recovery mode is not worked flash a stock recovery mode, copy the OS into the phone, install it from zip using recovery mode. Done.
    you can also use other recovery, but you might need to change some files in the OS so it is better you use the stock one.
    I suggest or learn these stuff, many articles in here or XDA to help you out, or go back to none Beta OS.
  15. Deactivated User
    Feb 2, 2019
  16. kunal4
    kunal4 , Feb 2, 2019 :
    Don't think that's true. Would've been on Android news sites if that were the case. If it's by design, it's done very poorly because the option is still there, but doesn't work. Should remove the option to turn if off if they aren't going to fix it.
  17. Deactivated User
    Feb 2, 2019
  18. shally4ualways
    Cupcake Feb 2, 2019
    shally4ualways , Feb 2, 2019 :
    Hi,After Android version 9 update in my op5,unable to update my play store application,pls help to resolve
  19. I1514816323480
    Cupcake Feb 2, 2019
    I1514816323480 , Feb 2, 2019 :
    Applications keep hanging or crashing. Headphones aren't working intermittently. OnePlus is losing its quality focus.
    davidjuarezalc likes this.
  20. Mr_Cyrox
    KitKat Feb 2, 2019
    Mr_Cyrox , Feb 2, 2019 :
    Well nothing that you mentioned is happening to me on OB 26
    Maybe you should focus on trying to fix things first?
